Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 04-12-2013, 12:17 PM
  #27721
Tony Newland's Avatar
Trader Rating: 53 (100%+)
Originally Posted by Smartypants
hmmmmmm
O ya!!!!!!!!!
Tony Newland is offline
Old 09-23-2013, 07:39 PM
  #27722
Red face Mi2
Hello Gentlemen and Ladies,
First Please don't shoot. I was wondering if drivers out there have experimented with different belts for the mi2. As far as using another brand other than the schumacher for belts, pulleys etc? Its been a little tough finding parts locally for it. In addition the pulleys teeth are starting to chip away. And I will have to get replacements. Totaling the parts that are needed I'm just over 75$ in replacement parts. I wanted my son to race this for vta and usgt once he has enough confidence to get the laps in. I just don't want to have to wait for the parts from the UK all the time. Any info would be much appreciated.
Thank you in Advance
sammyc656 is offline
Old 11-20-2014, 11:16 AM
  #27723
rcshark's Avatar
okay we know all kind of cars are out there. so I am sticking with my MI4cxl for now... I put the MI5 hubs around on my car with the 6 degree front carrier barrier. the car loosened up in the back dew to a shorter camber link location.
Should I raise the camber link plate or find another hub plate that will lengthen the camber link?
Thanks.
rcshark is offline
Old 02-03-2015, 03:46 PM
  #27724
WyldModMan's Avatar
Thanks.
IMO i would suggest finding a replacement stewart, i think you will then find your lap times improve, or stop procrastinating and buy the evo, use your cxl in vta. im just busting your cahohnas you have a great car, wouldnt raising you camber plte give you a lower roll center an more bite
WyldModMan is offline
Old 02-12-2015, 05:02 PM
  #27725
rcshark's Avatar
lol Thank you that works on asphalt. But on carpet i cant drop the center enough to keep from super gluing the front side walls? Plus the cxl is just to heavy and don't know how to make it lighter? tough car after installing the twin point steering with the mi5 hubs i have a good bump steer back! I thank i need to goto the carpet top deck and use the front then hex? I dont know if moving in the arms will be the same or not? Overall the car feels great and is just as strong as any car that i crashed. I thank i am going to drop the balls on the camber to free up the car on carpet? also try and move the rear inboard tow and see if it will carry more speed true the turns? car seems tight on carpet. but fun to run....
Shark
mi4cxl 17.5
front camber 2
rear 1
camber plates f/r stock #3 washer on top. flat on bulkhead.
everything else is stock.
4 degree camber blocks with mi5 hubs and carriers.
rear mi5 hubs.
stock top plate all screws tight.
droop 5 in front.
droop 3 in rear.
blue AE front springs. 17.00 lbs.
blue schumacher rear springs.16.00 lbs.
40wt. oil.
rcshark is offline
Old 02-12-2015, 06:26 PM
  #27726
rcshark's Avatar
Talking front hubs and mounts from mi5 to the mi4cxl
rcshark is offline
Old 02-12-2015, 06:43 PM
  #27727
rcshark's Avatar
Default mi5 hubs on cxl twin point for bump steer
Schumacher Corner-mi4.5-cxl-rear-end.jpg Schumacher Corner-mi4.5-cxl-front-end-camber-mi5-hubs.jpg
rcshark is offline
Old 07-20-2015, 07:38 PM
  #27728
Looking to buy the spools for the Schumacher Mi3 ( Part number U3225). Please could you let me know any reliable place to buy them online. I'm located in the United States. Is this a good online store:
http://www.racing-cars.com/pp/Old_Ca...3.5/U3225.html
cbs007 is offline
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
