Schumacher Corner
Congrads to Aaron and Mo for a dominating weekend with their Schumachers!!!!
Aaron TQ/win 19T (first race with Mi2EC)
Mod TQ/win Mo (still has it!)
Side notes;
Aaron's 19T run would of been second in mod
STLNLST should be in a dress again sporting the mullet
Side notes;
Originally Posted by PW
Congrats to Aaron and Mo for a dominating weekend with their Schumachers!!!!
Mo TQ/win Mo (still has it!)
Side notes;
Side notes;
Regional Moderator
Originally Posted by Jon Kerr
The problem with the EC and the front CVD pins is a flaw in the CVD design. The coupling in the stock EC CVD's is hollow. So there was nothing on the back side of the pin opposite the set screw to support the pin. If the set screw was tightened too much, it will bend or even snap the cross pin. So people were having the pins just break without hitting anything. (The new CVD's that are available have been revised and this isn't an issue any longer.) I had one stock CVD break the whole time I've been running the EC. I just tighten the set screw down enough to hold everything.
As for the spool being hard on the front end, yes it is. That's what the blades are for. Blades wear out fast on the EC with a spool. But as long as they're replaced before they're dead, there won't be any issues. The new spool will have a thicker out drive so the surface where it contacts the blade won't be so sharp. This should make the blades last much longer.
Thanks for the reply.
Regional Moderator
Originally Posted by AdrianM
We are way ahead of you on this...
There are other top cars on the market that have a problem with the screws holding the suspension mounts to the bulkhead bending. We have learned from this and as a result this is much less of an issue on the Mi3. The Mi3's you have seen are a prototype and an early Pre Production car that had a lot of proto parts on it so we could have a complete car at Nuremburg.
There are two diffrences in the Mi3's you have seen and what will be on the final Mi3 that make it a lot tougher in this respect than other cars on the market.
Originally Posted by Darkseid
So are any of the team guys using the final version yet, or is it still pre-production units for them too?
Alloy pivot blocks on Mi2EC
Hi! I just installed the U2742 alloy pivot blocks in the rear of my Mi2EC and according to my setup tools, one wheel is at 3 deg toe in and the other is 2 deg toe in. Anyone know why? Thanks!
Side notes;
Side notes;
Side notes;
Side notes;
I have never lost a mullet challenge
Only with that 3.5 that blew up. My 7x1 owned your 4.5. That motor is crazy fast. Too bad there is no more DC motorsports.
Just think about the beating you will receive once I get my Mi3. I hope soon.
Originally Posted by THeGame
WORD!! CHUCK!!!!
Originally Posted by Alex Lopez
WORD!!! Mo....pm about your motor situation for the Reedy race.
Wrote a song about it... Wanna hear it? Here is goes.
I lapped Clint
Every race
Rubbed the Mi2 right in his face.
Bring it on sucka!
I lapped Clint
Every race
Bring it on sucka!
