Xray T1
#9196
Originally posted by doki_doki
the main difference between the two servos is the size. next is the torque and response time. s9451 has a high torque and faster response time but heavier. s9550 has a lower torque and slower response time but lighter...hmm... which servo shall i put on the car then??? i have both servos...
#9204
most likely the plastic blades on the dogbones they get sloppy and worn after a few races of mod.
#9206
R/C Tech Elite Member
Originally posted by evaa
been running my foc for 4 races now, no slop yet
this is a transmitter question, what dual rate do you guys normally use? mine is set at 100, the fast drivers in my track apparently use only 65. what gives?
#9207
Who makes the best 64p gears that will fit the factory kit? I had some HPI gears but the mounting holes didn't line up.
#9208
I use these all the time: http://www.precisionracingsystems.com/default2.htm
Never had a problem, the work great. Hope this helps.
