Xray T1
#8446
Originally posted by Hodapp
S-T-R-I-K-E-R - What rear roll center are you using? Low roll center should step out the least. Inside hole on the arm will also help but you might lose some steering.
#8447
forty6 - Thanks. I was running the new front tower but not the new chassis. My complete setup, along with a race report will be on http://www.mytsn.com later tonight.
I read your report on the Xray website. It is interesting to see how much happier you were with the spool up front.
Do you know if Hara was running a spool as well. He dominated the Nationals running a spool up front in his PRO 4.
It seems that a one-way in no longer the best choice.
Where I race traction is always low due to dusty conditions so we never run one-ways as there is never enough grip to do so.
My point is that coming to the Worlds in October, should I take the risk and try a one-way on Wednesday Practice or would it be a waste of time and I should stick with a spool the whole event.
Your help would be very usefull.
Regards,
John Doucakis
Athens, Greece.
#8448
Hi guys, i've got some money to spend on my T1R and i was wondering what i could buy to make it better (mind you i'm only 13teen and can't aford to spend 100s )
Chazz
Chazz
#8450
John Doucakis - The worlds layout is going to be fast with a lot of sweeping turns so a oneway will probably be the faster of the two. I will pay close attention to what everybody runs at next weekends Florida state race and decide from there what I will start with at the worlds.
#8451
Xray T1 with foams
Hi guys
I own a Xray T1 and have decided to run foam tires on said beast. My problem arrises when I try to fit 30mm rear foam tires. The rear suspension basically wont allow such wheels/tires to fit.Other than changing the rear end to a "C Hub" type has anyone got any ideas short of cutting the rear supports?
#8452
Exactly what effect does the spool up front have on handling?
#8453
Re: Xray T1 with foams
Originally posted by Rolling Wreck
Hi guys
Hi guys
#8454
how do the short arms handle comparded to the long arms?? and since im currently driving a t1r is there anything i need to change when runing that new foam front(and or rear) shock tower?
thanks lazyboy
thanks lazyboy
#8455
hey,
i need some help guys.
im having problems with my Xray T1 (yes the original )coning tires
ive been told NOT to run more than 2 deg camber but the problem is that i keep getting coning on the outside of the tires. i run foams by the way.
at my local track im running the serpent red springs which are the hardest ive got (sorry i dont know the lbs) but im finding myself using 3.5 -4.0 deg of camber JUST to get the tires to wear flat. hence i believe im loosing a LOT of corner speed right?? seeing as the contact patch is so small.
my other dilemma is that i do not want to spend any more money on this car as im saving for a FK. i know roll bars would pretty much eliminate coning... but i DONT wanna spend more money
the only hop-ups i have on the car are a one-way... and a BMI 3mm chassis
WHAT CAN I DO>??????..
if you could help me i would greatly appreciate it,
thanx
robbie
thanx
robbie
#8456
thanks lazyboy
thanks lazyboy
#8457
Just got my Hudy Droop Block, Gauge and Hudy Ride Height Gauges in today. I was wondering how many mm and what ride height to be looking for. I run Carpet Stock.
So far, this is what i put:
Front: 0mm w/ 4.5 ride height
Rear: 1mm w/ 5.0 ride height
Should I change anything up? I was maybe considering 4.0 and 4.5 ride heights but that is alittle low. Someone LMK. THanks
#8458
Right now me and a few of the guys are running:
8mm in the front
7mm in the back
and 4.5 ride height
8mm in the front
7mm in the back
and 4.5 ride height
#8459
Re: Re: Xray T1 with foams
Originally posted by Neil Rabara
You will need to change the rear suspension to c-hubs. In fact, all the new Xray kits are equipped with c-hubs.
#8460
Originally posted by xray racer
hey,
hey,
