Xray T1
#8461
Up/Down stops
is it best to measure up and down stops with or without the shocks installed?
Always done them with, but figured it may be a easier time without. However, without shocks, can I truly get their limits?
^5s
^5s
#8462
Re: Xray T1 with foams
Originally posted by Rolling Wreck
Hi guys
I own a Xray T1 and have decided to run foam tires on said beast. My problem arrises when I try to fit 30mm rear foam tires. The rear suspension basically wont allow such wheels/tires to fit.Other than changing the rear end to a "C Hub" type has anyone got any ideas short of cutting the rear supports?
Hi guys
I was told by more than one person, that 28s are more than adequate for traction when running foams [currently, my "home" track is indoor & considered to be a medium to high bite track on ozite carpet-plaids and purples are most common on front & rear, respectively].
Hope this helps [but like in cooking, everyone has a different recipe].
^5
#8464
Woohoo they fit
Tried a bit of both ideas and now the wider foam wheels fit on the car. Mind you had to look closely to make sure there was actually some clearance.Spaced out the rims with spacers and then touched up the rims ever so lightly and bingo they fit.Thanks guys am sure there will be more things I will need help with
#8465
Woohoo they fit
Woohoo they fit
If spacers are a must, look for an off-set [tire/wheel] that will give you the clearance you need and still keep to specs! Some tracks and racers [who will more than generously point the "discrepancy" out] can be very particular to specs. Most are good to and allow you to "run what you brung", until you get into big, sponsored and/or sanctioned event(s).
^5s
#8466
Woohoo they fit
Woohoo they fit
#8467
Re: Up/Down stops
^5s
^5s
#8468
Registered User
ball diff
does anybody know where i can find a factory ball diff im have no luck and need one soon thanks for your help jesse
#8469
If you look in the setup book, pages 16 and 17, you will see that the shocks are not on the car when the downstops are measured.
I do it like the book says....
#8470
Re: ball diff
#8471
^5
#8472
Thanks for your answer. What prompted this whole thing was an over haul and thought about checking/setting the up & down stops, and then, the revelation of "what about about shock travel"? So, I thought I'd ask.
^5
^5
#8473
this is not true with the short arms. when you setup for carpet, the spring combination is soo stiff, that it actually twists the rear arms and the droop is actually more then what you would set without the shocks in place.
#8474
#8475
most guys are running purple spring and some into the red with mod. that is the standard setup for carpet. Take a look a josh's, or alex's carpet setup. These I guantee will twist the arms. I think almost .5 mm of difference with and without the shocks installed. This is a know issue with the flexability of the short arms. you have to remember with the short arms, the droop screws are on the opposite side of the arm as the shock mount and also on the opposite end. so with the shock install it will always put a twist in the rear arms.
I have asked several people including josh. basically they are either setting the droop with block without the shocks, or they are setting the dropp using uptravel and forgetting the blocks. What you could do is a combination of both. set the droop with the block to get them even, and then check uptravel that both side are traveling the same amout.
