Xray T1
#8611
has anyone tried using shock foam inserts? how was it?
#8612
Hodapp and I both run 2 o-rings between the cap and bladder
#8613
what will it contribute in terms of shock performance? would it make it more consistent?
#8614
Hi, what are the performance gains of the low ratio pulley's over the regular set? Thanks
#8615
Here is one that fits perfectly for both Xray and Serpent shocks,
PITZHIMITSU-PS0902 Silicon Soft Diagfram + Sponge Set
The 2 o-ring type to replace the sponge has first been used (that I know of) by Surikarn C on 414M era.
#8616
#8617
#8618
Low pulley set
I started putting my low ratio pulley set on, and I think I need something else. Do I need a different spur gear shaft? The front belt seems awful loose and there was an extra gear in the bad that was a little bigger. It just wont work though (no place for the one-way bearing to go). So I guess I need to know is there a different shaft I need to buy?
#8619
Yes you'll need the solid aluminium layshaft to fit the low ratio pulleys. The extra pulley that comes with the low ratio pulley set is for a one way/spool.
You can't use the central one way with the new pulleys.
#8620
Originally posted by Tom G
What are you looking for? My LHS has a wall full 'o them [they are out of shock membranes].
Let me know [actual $$, tax,paypal & s/h; I'm not looking to make a dime] and I'll call them and let you know if they are in stock and when I could get them & sent.
BTW, they usually beat Stormer's hobbies prices by about 10%, which would make up the difference in the tax and help cover some of the other charges. Xray is a prdominant ran kit at the track, so he does pretty well by the racers and their commonly needed kits/parts.
^5
Tom G
^5
Tom G
#8621
i don't think that mike has any factory diffs or new thick chassis. As far as front shock tower, I think that there are carpet shock towers. Have not heard of "new" front shock tower.
I don't think that you are going to find the new chassis in the states. Not until RCAmerica gets their first shipment.
#8622
My stock FK shocks leak slowly and I have to refill them after a couple of days racing.
#8623
#8624
Originally posted by Qwiglee
Is this some kind of performance gain or is it to stop leaks or both?
Chazz
#8625
Right now I am looking for the T1FK complete differential assembly, the new thicker chassis and the new front shock tower.
Got any part #s I could use to make the call?
But I think Theisgroup is right, Mike's won't have the latest stuff yet. I could still check, though.
LMK
^5
