Old 08-24-2004, 09:03 PM   #8611
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
has anyone tried using shock foam inserts? how was it?
S-T-R-l-K-E-R is offline   Reply With Quote
Old 08-24-2004, 09:05 PM   #8612
Andrew Swanson's Avatar
Send a message via AIM to Andrew Swanson Send a message via Yahoo to Andrew Swanson
Hodapp and I both run 2 o-rings between the cap and bladder
Andrew Swanson is offline   Reply With Quote
Old 08-24-2004, 09:11 PM   #8613
what will it contribute in terms of shock performance? would it make it more consistent?
Old 08-24-2004, 09:34 PM   #8614
Deves's Avatar
Hi, what are the performance gains of the low ratio pulley's over the regular set? Thanks
Deves is offline   Reply With Quote
Old 08-24-2004, 09:39 PM   #8615
Pyramid's Avatar
So that the diagfram does not get in stuck on there since no force (sponge or others) to pull it back in.
Here is one that fits perfectly for both Xray and Serpent shocks,
PITZHIMITSU-PS0902 Silicon Soft Diagfram + Sponge Set
The 2 o-ring type to replace the sponge has first been used (that I know of) by Surikarn C on 414M era.
Pyramid is offline   Reply With Quote
Old 08-24-2004, 09:42 PM   #8616
Pyramid's Avatar
Less stress on drive train thus prolonge the life of all moving parts (bearing is the most commons ) I also found gain in motor performance, for ex, geared 1 tooth higher.
Old 08-25-2004, 12:29 AM   #8617
Neil Rabara's Avatar
That's one hell of a rebound. But if it works.......why not.
Neil Rabara is offline   Reply With Quote
Old 08-25-2004, 07:50 AM   #8618
JHardy's Avatar
Default Low pulley set
I started putting my low ratio pulley set on, and I think I need something else. Do I need a different spur gear shaft? The front belt seems awful loose and there was an extra gear in the bad that was a little bigger. It just wont work though (no place for the one-way bearing to go). So I guess I need to know is there a different shaft I need to buy?
JHardy is offline   Reply With Quote
Old 08-25-2004, 09:21 AM   #8619
Robfo's Avatar
Yes you'll need the solid aluminium layshaft to fit the low ratio pulleys. The extra pulley that comes with the low ratio pulley set is for a one way/spool.
You can't use the central one way with the new pulleys.
Robfo is offline   Reply With Quote
Old 08-25-2004, 09:21 AM   #8620
Qwiglee's Avatar
Originally posted by Tom G
What are you looking for? My LHS has a wall full 'o them [they are out of shock membranes].
Let me know [actual $$, tax,paypal & s/h; I'm not looking to make a dime] and I'll call them and let you know if they are in stock and when I could get them & sent.
BTW, they usually beat Stormer's hobbies prices by about 10%, which would make up the difference in the tax and help cover some of the other charges. Xray is a prdominant ran kit at the track, so he does pretty well by the racers and their commonly needed kits/parts.
^5
Tom G
Right now I am looking for the T1FK complete differential assembly, the new thicker chassis and the new front shock tower.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 08-25-2004, 09:29 AM   #8621
theisgroup's Avatar
i don't think that mike has any factory diffs or new thick chassis. As far as front shock tower, I think that there are carpet shock towers. Have not heard of "new" front shock tower.
I don't think that you are going to find the new chassis in the states. Not until RCAmerica gets their first shipment.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-25-2004, 10:44 AM   #8622
Qwiglee's Avatar
Is this some kind of performance gain or is it to stop leaks or both?
My stock FK shocks leak slowly and I have to refill them after a couple of days racing.
Brian Aldridge
Old 08-25-2004, 10:45 AM   #8623
Qwiglee's Avatar
Thanks for trying to help. That is why I was looking overseas to begin with. Nobody in the U.S. has parts left in stock.
Brian Aldridge
Old 08-25-2004, 01:54 PM   #8624
Maybe the shock seals are broken (grit might have got them)
Chazz
Chazz is offline   Reply With Quote
Old 08-25-2004, 03:18 PM   #8625
Tom G's Avatar
Front or rear diff?
Got any part #s I could use to make the call?
But I think Theisgroup is right, Mike's won't have the latest stuff yet. I could still check, though.
LMK
^5
Tom G is offline   Reply With Quote
