Xray T1
#9046
question on degrees
I was running yesterday 3* c-hubs and wanted to try something different maybe 6* c-hubs but is there anyway i can but a 1mm shim on the bottom some where so i can get 4*? Just wanted to try something different so i can be more aggressive in the turns.
-Jon
-Jon
#9047
Originally posted by JDXray
the difference between them is that, the smaller ones are for pivotball suspension (but you need the smaller pivotball steering blocks) the 22mm are for the c-hub and steering block conversion. I use the 22mm for my xray in the front there is no need in the back since they dont get grooved.
I appreciate your reply and I guess since it is for a FK with C-hubs then I guess that answers my question.
Thanks, Mike
#9048
no problem mike, just try and get some 22mm ones, my friend bought the smaller ones before and was disappointed when they didnt fit either steering block for c-hub or pivotball conversion. (he had to go and buy a smaller pivotball steering block for it to fit. But then that broke since it was smaller so he went back to the regular ones)
-Jon
-Jon
#9049
Re: question on degrees
-Jon
-Jon
#9051
Originally posted by Michal101
Pyramid,
YES, I know! I have read all pages, but there was different info posted on other boards and I guess my actual questions is "what really is the advantage or benefits of the XRA305215(smaller ones) over the XRA305315 or vice versa?"
Besides, the forum needed a Bump anyway.
Mike
Pyramid,
Mike
Please go to page 300 started with post made by Besercoe at 9-17-2004 at 12:47pm. That's what exactly what your answer is. I hope no misunderstanding here
#9052
I heard more caster meaning 3 to 6 would make steering more aggressive. Now i am confused.
#9053
Originally posted by Pyramid
Hi Mike,
Hi Mike,
I did read that and he was asking about the differences between front and rear(which I knew) but I wanted to make sure that when Xray went with the FACTORY kit, with short arms, that nothing had changed pertaining to the axle hubs.
Rather be safe than sorry!
JD, I too thought that more caster would give you more initial turn in, but here is what I have found.
More caster aids stability, especially at high speeds.
More caster generally suits large, open, high-speed tracks.
Less caster increases steering drastically.
Steering feels much more direct, the car turns tighter and faster.
Small amounts of caster are suitable for tight tracks.
I got this from a setup forum somewhere.
I hope it helps, Mike
#9055
Please browse couple pages back. It"s been mentioned about 3 times within a month.
Had I been reading this thread when he asked, I know I would have.
Rob
#9056
Originally posted by losirob
You know, in the time it took you to post this reply, you could have just posted the information for him.
Rob
Rob
I appreciate it and that is what I thought these forums are for.
Thanks, Mike
#9057
thansk mike, then i do need to change my caster. I run at a track that is very fast. But still no one has anwser my question before.
Is there any way i can get 4* by using a 3* and shims? If not then i will jsut go to 6*.
-Jon
-Jon
Rob
#9058
Rob
Rob
#9059
#9060
I think the XRay parts lists are the most confusing I've ever had to use... I can't count how many wasted minutes I've spent at the LHS trying to figure out which part number is correct for the part I need.
Rob
Rob
