Xray T1
#7546
Thankyou Evaa!!
#7548
Originally posted by Andrew Swanson
they are a few thick chasis floating around and yeah the BMI chassis is good but i have an akward feeling we are using the stiffer chassis to make up for A ARM FLEX the arms are like water and so if anyone has some freetime and wants to try what ive been playing with try using the stock chassis and try BEEFING UP or STRENGTHNING the front and rear a arms.
HUGE difference
HUGE difference
#7549
The short arms FEEL hard as they are so short-but when mounted on the car and trying to set uptravel (droop)-its hard to get a consistent reading because the arms bend so much when the droop screw contacts the chassis.
I to am waiting to hear how Andrew stiffened his short arms. I know the teams guys were putting JB weld in the original soft arms for carpet!! I/we could try that-thugh the arms get heavier then-and thats not a good thing!!
Ray
Ray
#7550
Setup for 6 Cell on one side
Does someone have a setup for XRAY T1 Factory that uses 6 cells all to one side and electronics on the other side?
I am borrowing the car for the next two weekends and do not want to break up my glued packs because they will eventually go back to my other car which uses a side configuration.
#7551
You might as well break them up. Once you drive the car...you won't want to give it back Try www.mytsn.com. There's probably something there.
Blake
Blake
#7552
you i agree once you try an x-ray you would eventually end up with one. great car superb especially the FK!!!
#7553
I was thinking of trying a xray for the first time, getting the factory kit. Would anybody recommend putting the molded chassis on if it would be race outdoors? I'm not sure how well the carbon fiber chassis holds up to the usual dots and boards and asphalt. Any opinions.
#7555
#7556
Well, I just switched over to an XRay from a TC3. I have wanted an XRay for a long time, and it is great. So now, I have to subscribe to this thread!
It was the best kit (assembly wise) I have ever done. All the parts fit perfectly, with no binding anywhere.
I just have a few questions. How often do the belts wear out (stretch out too much) and require replacing if running stock and 19T? Also, what are the most commonly broken parts (I'm guessing front arms and carriers, but let me know)?
Thanks,
etzkev
Thanks,
etzkev
#7557
Re: Setup for 6 Cell on one side
#7558
Location: Built By The Racers For The Racers. Corona CA
Thanks,
etzkev
Thanks,
etzkev
This car is built rock solid!!!!!!!!
#7560
well the first set i did i just cut up a old top deck and gllued it to the top of the arm (ill post pics tonight when home from school)
but im doing another set with 1/16 inch woven graphite glued on both sides of the arm and also using alot of glue in the arm slots.
another way i thought up today is thrown some wax paper down and mix up some epoxy anf fill the arm and then just cut and glue some lexan to the top and bottom of the arm.
front arms are still a work in progress but im thinking of maybe drilling a hole in the caster block and running a tie rod to the bulkhead to stop flex.
the arms i ahve right now are only a few grams heavier then stock. i would say in all ive added 1/4 oz to the car which is nothing considering my car is like 3oz under.
once again its only an idea i have and just someting to try an ill post pics later.
