Like Tree3Likes
Xray T1
Old 08-29-2001, 01:25 PM
  #46
David Galdo's Avatar
Trader Rating: 15 (100%+)
Carbide and ceramic diff balls are an excellent upgrade. Go to http://acerracing.com/ for the diff balls.
David Galdo is offline
Old 08-30-2001, 09:53 AM
  #47
Thanks for the help. I talked with Atomic and they should have the parts some time next week. They were out of the front suspension stuff, one-way and bars. Hope to get the car on the track in the next month.
MK
SamIAm is offline
Old 09-01-2001, 07:25 PM
  #48
dtm
dtm's Avatar
Default Re: Gritty Diff?
Originally posted by Joe
I would have checked new diff rings but my LHS doesn't have any. I don't get it. Anyone have any ideas?
Joe- Use one half of the diff to hold the rings down and polish them on 2000 grit wet n dry paper (use with water). You can easily achieve a mirror finish back on the diff rings. Remember to clean everything really well after you finish, the grit from wet n dry paper will wear everything out real quick if left in the diff!
I've been using this method since I bought the car...... over 150 packs and probably 5-6 rebuilds and I'm still on my original diff rings!
Before anyone mentions anything about being "cheap" I would recommend they try it first.... My diffs are easily smoother than the original setup !
dtm is offline
Old 09-01-2001, 08:50 PM
  #49
Joe
Joe's Avatar
Default Thanks
Cool, thanks for the replies. Unfortunately, it's still gritty. Looks like I'll just have to buy new rings and balls.
Joe is offline
Old 09-01-2001, 08:56 PM
  #50
Joe,
Did you completely tear apart the diff to see if its inners where improperly assembled?
Otherwise go for the new diff balls and rings.
Old 09-01-2001, 09:15 PM
  #51
Joe
Joe's Avatar
RCCadet, yes I did. It looked fine to me. Polishing the diff rings did help a little, but not much. Oh well.
Joe is offline
Old 09-01-2001, 09:21 PM
  #52
Well if the new parts do not work out, send it to me and I will send mine to you, since I am using a one-way any how. I will e-mail Ralph about it and eventually fix it for myself since you will have my smooth diff.
Old 09-01-2001, 09:27 PM
  #53
I am sitting here spinning mine in my hand and since it was never really tightened for better steering into and out of turns it is still a virgin diff. I used a lithium based grease with teflon so it is smooth.
Old 09-02-2001, 02:05 AM
  #54
dtm
dtm's Avatar
Did you replace the 2.4mm balls?... this is pretty much a throw away item. The small thrust bearing can usually last for quite a while. To extend the life of the thrust bearing you can flip the small diff rings over and re-use (note the different sizes!). The thrust bearing is the only part that is damn expensive... everything else on the car is cheap!
dtm is offline
Old 09-02-2001, 05:13 AM
  #55
DTM: Joe said he checked every thing in the diff halves. It puzzles me too. I was thinking that the parts in one of the output halves were not assembled correctly but he said he checked it all. It doesn't seem right some how considering I've had my kit (1st batch) since March and the rear diff is smoooooth!
I have my car in pieces right now and removed the shieldings from the bearing for a good cleaning. My one-way is in need of a cleaning. As much as I have run the car lately I will have to break it down twice a month if not after every weekend of racing.
Old 09-04-2001, 12:13 AM
  #56
Manticore's Avatar
Manticore is offline
Old 09-04-2001, 04:33 AM
  #57
dtm
dtm's Avatar
Oh dear Manticore....... thats a lot of money on upgrades that you have just introduced!!!!
dtm is offline
Old 09-04-2001, 04:46 AM
  #58
dtm
dtm's Avatar
Just thinking out loud here. But could you possibly end up with a gritty diff if you reverse the two small diff rings on the thrust bearing. The smaller dia hole ring should be against the head of the screw to align everything.
If you have the large dia ring against the head of the screw instead the rotation of the thrust bearing will mean the rotation of the larger diameter ring which may be rubbing against the inside of the diff. This ring is normally static. Maybe a possibility....?!
dtm is offline
Old 09-04-2001, 08:59 PM
  #59
Manticore's Avatar
I built my two diff out of stock box. they are great and i dont see any problem with the diff. are you guy just too picky?
Old 09-05-2001, 03:51 AM
  #60
dtm
dtm's Avatar
I've got to admit that my car runs better (handling more predictable) when the diffs are slightly gritty than when they are super smooth! Maybe its just an excuse of mine to delay rebuilding the diffs!
dtm is offline
