Like Tree3Likes
Xray T1
Old 09-08-2001, 10:33 AM
  #76
David Galdo's Avatar
Trader Rating: 15 (100%+)
I balance my chasis with out the battery. I figured that the batteries, 2000 or 2400, vary in weight a bit so I did not factor it in.
David Galdo is offline
Old 09-08-2001, 11:10 AM
  #77
Regional Moderator
Darkseid's Avatar
Manitcore: But without the motor opposite the battery, wouldn't it take quite a bit of weight to offset the battery? That would also make the car quite heavy wouldn't it?
O'well I guess Xray has accounted for all of this already, I don't see how though. I still like the usual battery layout for the T1 and Corally C4.1.
Darkseid is offline
Old 09-08-2001, 01:06 PM
  #78
dtm
dtm's Avatar
Maybe Xray are thinking about breaking into the "Oval" market!
dtm is offline
Old 09-09-2001, 12:02 AM
  #79
safaridog's Avatar
Is it just me or does the 24 tooth pinion they supply in the kit very under geared? I pretty much find useless with the 90 tooth spur that came with the kit. I ended gearing it 31/90 with a 11x2 just to keep up. What's everone else geared at?
safaridog is offline
Old 09-09-2001, 03:20 AM
  #80
dtm
dtm's Avatar
Woo.... 90/31 for a 11x2, thats a total gearing of 6.169 you must run on a very large track or have a very "hot" motor at the end of the pack. I run 125/35 total 7.589 with an 11x2 on a tight technical track. At 125/36 my brushes will start to discolour!
dtm is offline
Old 09-09-2001, 03:22 AM
  #81
Manticore's Avatar
you're not running 7T single?
Manticore is offline
  #82
dtm
dtm's Avatar
Originally posted by Manticore
xray has some nicely made lead weight for the purpose of balancing the chassis.
I wonder if you can stack 10 of them together and make an antenna!
Have you seen these in Mong Kok yet Manticore?
dtm is offline
Old 09-09-2001, 03:24 AM
  #83
dtm
dtm's Avatar
No lah.... thats reserved for my micro!
11x2 is my favourite motor for PYC!
dtm is offline
Old 09-09-2001, 03:50 AM
  #84
Manticore's Avatar
i have a fantom 11T arm on a D3.5 can with similar gearing. I forget what gearing i have.
Old 09-09-2001, 03:51 AM
  #85
Manticore's Avatar
you do it first !! it is illegal. joe's police RC car will chase at your tail !
never seen it in MK.
Old 09-09-2001, 10:51 AM
  #86
safaridog's Avatar
we run on a above average track size , it measures 160' x 80'
check it out
http://members.home.net/rccar/
we just held the Canadain nationals last weekend.
Old 09-09-2001, 03:09 PM
  #87
I run 87/31 with my 12x3 D2.
Old 09-10-2001, 04:04 AM
  #88
[QUOTE]Originally posted by 29TC
Is there anymore X-Ray T1 Kits with Hudy-set Up combo out there?
I am assuming, the above quote that the T1 kit came with the Hudy set.
[/QUOTE
There's a T1 kit at my lhs has one with the Hudy-set up, They only have one in the store. It's in Daly City Ca.
Damo: I'm intrested in the wrenches only, let me know how much you want them for it, if over 40 don't bother, i could get it for 50 from a friend.
milf is offline
Old 09-10-2001, 04:39 AM
  #89
RCCadet - How does the T1 handle compared to your TC3. I am about to buy a touring car and trying to choose between the T1 and the Losi.
I have found a T1 with the Hudy set up tools. Can someone please tell me what tools come with the set up?
jingle is offline
Old 09-10-2001, 06:37 AM
  #90
dtm
dtm's Avatar
check it out
Nice track... does your brushes not change colour with that gearing?!
dtm is offline
