Old 09-26-2004, 08:48 AM   #9196
Neil Rabara's Avatar
Originally posted by doki_doki
the main difference between the two servos is the size. next is the torque and response time. s9451 has a high torque and faster response time but heavier. s9550 has a lower torque and slower response time but lighter...hmm... which servo shall i put on the car then??? i have both servos...
Only you can answer that question.
Neil Rabara is offline   Reply With Quote
Old 09-26-2004, 02:35 PM   #9197
JDXray's Avatar
Send a message via AIM to JDXray
I have found out now that my track has moved to 19t spec now.. Should i change anything on the car for 19t racing? I wasnt sure because 19t is pretty close to stock.
Jon
JDXray is offline   Reply With Quote
Old 09-26-2004, 02:39 PM   #9198
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
Post
Hey Jon you could use the exact setup ,no need to change anything (only the motor )I drove Jackies car 19 t with the same setup he uses for stock and the car was hooked up!
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 09-26-2004, 02:50 PM   #9199
JDXray's Avatar
Thanks Sal,
Nice i dont have to do anything.. I all gotta do is spend some cash on 19t...
After you left there was some mod motors being run.. 12t hara edition...
Old 09-26-2004, 02:56 PM   #9200
Sal Amato's Avatar
seems like everytime I leave it starts to get good,better off any way because I would of put a mod in and probably break my car . I have to get a new servo mine is no good.
360 RC SPEEDWAY 2.0
Old 09-26-2004, 03:23 PM   #9201
JDXray's Avatar
no after you left, willis got quiet, only around 6 people were there.
Ya gotta start stocking up on parts, because the crash ratings will be alot higher.. I do not know how there gonna do the Enduro with no pit area...
Old 09-26-2004, 06:13 PM   #9202
Corey Bernardo's Avatar
Send a message via AIM to Corey Bernardo
I am curious about something.... I heard from someone, that it is good maintence to change some part plastic part on the xray car, like every other week? Which part might this be.. thanks
*TLR* *Losi* *Horizon Hobby* *Factory Novak* *Team Trinity/Epic* * JConcepts* *Xcelorin* *Spektrum* *Nitrotec* *Nitrotane* *UpGrade RC* *Toyz4Boyz* * Team Cypress*
Corey Bernardo is offline   Reply With Quote
Old 09-26-2004, 06:20 PM   #9203
JDXray's Avatar
umm i havent heard this before, but maybe the front bumper brace (top one) ?
Old 09-26-2004, 06:23 PM   #9204
most likely the plastic blades on the dogbones they get sloppy and worn after a few races of mod.
zjp_rc_racer is offline   Reply With Quote
Old 09-27-2004, 12:59 AM   #9205
evaa's Avatar
been running my foc for 4 races now, no slop yet
this is a transmitter question, what dual rate do you guys normally use? mine is set at 100, the fast drivers in my track apparently use only 65. what gives?
evaa is offline   Reply With Quote
Old 09-27-2004, 02:01 AM   #9206
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dial your dual rate to 100% then set your EPA to go full right and full left, without going over. Then just find out how you like to drive it, I have driven with my dual rate at 125% on some tracks, and 55% on others, just whatever feels best to you.
Old 09-27-2004, 09:09 AM   #9207
Qwiglee's Avatar
Who makes the best 64p gears that will fit the factory kit? I had some HPI gears but the mounting holes didn't line up.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 09-27-2004, 09:23 AM   #9208
JCB
JCB's Avatar
I use these all the time: http://www.precisionracingsystems.com/default2.htm
Never had a problem, the work great. Hope this helps.
JCB is offline   Reply With Quote
Old 09-27-2004, 09:56 AM   #9209
rayhuang's Avatar
Can anyone confirm existence of Hard rear short c-hub arms? And if yes-a part number?
Ray
Old 09-27-2004, 10:25 AM   #9210
JDXray's Avatar
Yes there are HARD REAR ARMS. dont have the # on hand but i have some.
Jon
