-   -   TC3 Forum (https://www.rctech.net/forum/electric-road/29-tc3-forum.html)
True R/C Racing 04-21-2004 05:19 PM
if you want i got a Set of threaded shocks in perfect cond for sale
for about $30-35:confused:
R3VoLuTiOn 04-21-2004 06:39 PM
no thanks on the shocks although id like them, im trying to keep costs down. im planning on running stock, ive got a monsterstock right now and ive got a new armature for it on the way for racing. i guess foams are good, about how much would a 0.1 second or faster, 100+oz-in torque servo go for used?
True R/C Racing 04-21-2004 06:41 PM
wow .01 sec Servo?:confused: :lol: if you find that let me know.
For a .11 which is fast with about 120-130 torque its like a Futaba 9450,futaba9451 aroun 50$ used.
for a .06 sec 130 torque your looking at around 75$:D
Bubblestc3 04-22-2004 10:54 AM
He said "0.1 second servo", not .01...
:weird:
Cain 04-22-2004 11:27 AM
Hey all.
I got a BMI TC3 that I am using the Reedy heatsink / fan. Works great. Just a few questions:
1. I heard that if you put the input for the fan in the battery spot instead of the third channel you will get more rpm for the fan, is that true?
2. I got the old arms on my tc3 with the single holes. So far the car handles well, what will getting the new arms and mounting to the new arm position due on the car?
3. I just ordered a set of sway bars to have as a tuning option as I run on carpet. When running the sway bars front and rear, what will the car feel like ? I am looking to get quicker change of direction as it seems I am getting alittle bit more chassis roll than I like.
Thanks!
runnin rc10 04-22-2004 01:07 PM
i never understood tire selection for asphalt (i race carpet) but I have asked around and I know for a fact that on nitro Touring Cars foams are used, so im assuming that they would be used on electrics too. Ask some of the people at your local track, see what compounds they are runnin.
Roger 04-22-2004 10:18 PM
front spool
anybody know where I can buy one ( website, hobbieshop, etc.. ) thanks in advance guys.
Advil 04-22-2004 10:23 PM
Roger,
Get with me on Saturday at Sheldon's. I have one that I will loan you.
Art
Roger 04-22-2004 10:57 PM
Originally posted by Advil
Roger,
Art
Thanks Art
Rory 04-23-2004 01:18 AM
Cain: Nobody uses the 2nd inner hole on the rear arms as far as i know, so don't bother with them. The front are only really used if you run a rear shock tower on the front, in which case they're a necessity. so if you get them for the front, might as well get a spare rear shock tower at the same time.
i really like swaybars on the car in most situations, they give a quicker change of direction and somehow often seem to give more grip as well :weird: but then i race on asphalt so it might be completely different on carpet
Nrctc3 04-24-2004 09:59 AM
I just got one of those JCE Racing heatsink/fans I'm gonna review it for www.RCXotic.com
Also what should pinion gear should I run with a 19t motor w/ a 100t spur. I'm running 64pitch. I know it depends on the track, but what are you guys running?
John_S 04-24-2004 10:08 AM
hi guys, i jsut got a tc3 after not having one for like a year or so. It has some delrin it hink bevel gears with ti but they dont really fit in it has the delrin diff gear fitted but the bevel gear wont fit properly is thre any modificatio to be done to these for them tio fit
Cain 04-24-2004 12:57 PM
Whats the 19 turn motor you are using?
Nrctc3 04-24-2004 01:00 PM
Chameleon & Axiom 19t (C2 design).
Cain 04-24-2004 07:02 PM
I would start my gearing at the 36 degree stock motor setting, which for you would be about a 36 tooth pinion.
Start there and monitor motor temp.
