The Speed Passion Thread >
Like Tree57Likes
Old 05-10-2011 | 11:26 AM
  #7081
Originally Posted by RevMaxx
am running SP GT2.0 on my 12th on 1S batt.
is there a new FW that would work really well with V3 SP 4.0T motor? base set-up would be greatly appreciated
currently running 508MOD FW but am having ESC thermal at end of 8 min run. If i tone down timing (DMTS) to get cozy temps after 8-min run, i feel its too slow down the straight.
Already released the new software....unload the 528mod and run the new 119mod. Sorry, no setting for that cause indoor carpet is over here....325 foot 1/8th outdoor track for mod on road is the way to go now....
Let us know if you find a good setup...and I can post of SP site.
P.S...1 piece of advise, when running 12th scale....turn off lipo cutoff and turn off thermal..............I never use any of these setting, I just don't like any FALSE alert that could cause me the race...especially the 8 mins main...you are running the lipo and esc down....who cares about the thermal cutoff warning..?
Solara is offline
Old 05-10-2011 | 11:36 AM
  #7082
Hi Solara, do you have a good starting point for 119mod firmware on touring cars?
I'm currently running a 6.5 Turns SP v3 on a GT2.1 prostock esc.
Thanks!
Fastfreddy74 is offline
Old 05-10-2011 | 04:41 PM
  #7083
4wheeldrive's Avatar
I have a 13.5 V3 and the sensor wire port moves a bit too freely. If I connect the sensor wire the tension of that wire will actually move the sensor board. Is there a way to keep the sensor board in place? I have seen the video on the Speed Passion site that shows how to take the motor apart and mine does in fact have the two rubber gaskets/grommets. Not sure how to keep the sensor board from moving on its own.
4wheeldrive is offline
Old 05-11-2011 | 12:56 AM
  #7084
Redwood's Avatar
I had a similar issue, I simply cut out a thin piece of cardboard and placed it between the sensor board and rear housing, to make a snug fit. Worked perfectly.
Regards
Neal
Redwood is offline
Old 05-11-2011 | 01:11 AM
  #7085
RevMaxx's Avatar
thanks for the advise...
i'll test the 119, if i can run it fast in 8-min and i can still place my finger on the ESC heatsink after the run , i'll post my set-up.
thanks again...
RevMaxx is offline
Old 05-11-2011 | 01:42 AM
  #7086
M7H's Avatar
M7H
Originally Posted by marcel p
wat is your f.. problem?only reacting on me! got a problem with me?
just joking around. we now the tekin guy so!
Not yet, only if you are faster then me.
and my speedpasion is faster as your hobbything! lol
That would be really strange you know...
M7H is offline
Old 05-11-2011 | 07:54 AM
  #7087
Thanks!
Sorry, I don't...but I would guess this is a good starting point. (Depends on the size of track...)
5* (middle) timing on 6.5 V3 motor, should use silver purple rotor RM13802NA
FDR 7.0~7.5
DRRS Level 7 or 8
Boost Timing = 16*
Slope = 18*/0.1s
SC Timing = 10*
Boost start RPM = 8000
Delay (depends on track length) = 0.2s or more...
Boost Timing Acc = 500rpm/degree (just a guess...)
Give that a try...if it is good, come back and let us know...and I will post it on SP website...thanks.
Solara is offline
Old 05-11-2011 | 08:02 AM
  #7088
FDR 7.0~7.5
DRRS Level 7 or 8
Boost Timing = 16*
Slope = 18*/0.1s
SC Timing = 10*
Thanks, I'll try your suggestions this sunday
BTW what's the difference between stock rotor and RM13802NA?
Old 05-11-2011 | 08:09 AM
  #7089
Regards
Neal
You need a new sensor holding unit like this one...
Solara is offline
Old 05-11-2011 | 08:10 AM
  #7090
I would only recommand the silver purple rotor IF your track is big enough...I don't want to go to the detail, all I know is....FASTER (when I used it on large outdoor track).
Solara is offline
Old 05-11-2011 | 08:13 AM
  #7091
i have tried my SP6.5 with the new stock timing on a large open track and it is SOOOOOOOO quick , i will do some more tesing this weekend and report back
great softwere
sidecarphil1 is offline
Old 05-11-2011 | 08:15 AM
  #7092
great softwere
If it is any good...please share your setup with us, thanks.
I too would love to use BOOST and slower motor and compare with the straight software (no boost/sc) with 4.0T motor...my guess is, boost 6.5 is just as fast as 4.0T but with better low-end (infield) performance then 4.0T.
Solara is offline
Old 05-11-2011 | 08:23 AM
  #7093
ok heres my starting softwere
6.5SPv3 middle timing
drag brake 20%
DDRS lvl 3(low grip dusty track)
boost timing 36 degrees
Turbo open time 6degree/0.1sec
turbo 15 dergees
boost start rpm 10,000
turbo open delay 0.4sec
boost timing acc 500rpm/deg
Gearing 7.2
Old 05-11-2011 | 08:24 AM
  #7094
Well my track isn't really big, the main straight is about 35m, but on race day it's sprayed with sugar so traction is always medium/high... I'll give that a try. Thank you!
Old 05-11-2011 | 08:41 AM
  #7095
Infact, you should try the ABOVE testing...he too running 6.5 but with 323STOCK...even faster then 119mod.
Solara is offline
