Old 03-11-2007, 01:27 PM   #17821
Trader Rating: 59 (100%+)
Send a message via AIM to todb
i am thinking of getting a msx to try out. i have never had one and plan to race carpet,stock,foam with it. i have a t2 already but i have always liked the 415msx and figured i would try it out. any pointers or ideas that i should know about? the car i am looking at is the msx not the mre. thanks for any help that is provided
OVA Neo. HW, Motiv.
Orange is faster.
todb is offline   Reply With Quote
Old 03-11-2007, 04:15 PM   #17822
Wing Chun's Avatar
Hi Mate
Go to Tryhards website for some great set up tip's as a starting point and good luck with the car.
There are a great bunch of guy's on here and help is on it way I am sure.
I run outdoor on rubber and I am not much help to you on indoor setup's.
Link below For tryhard
http://www.thard.co.uk/
Addam
Wing Chun is offline   Reply With Quote
Old 03-11-2007, 05:42 PM   #17823
TryHard's Avatar
Hi guys,
Right had an opportunity to test out my changes to the MRE this weekend... mainly to get the car to steer mid corner. As I already posted, I've added more ackerman spacers (to match the steering on the Evo5), and changed a few other small things.
The result? Well the car was simply stunning today, no steering issues what so ever, and numerous other comments about how good and hooked up my car looked. Was good enough for easily my best result of the year so far, Q'ing 8th O/a in 27t at the last round of Carpet Wars over here... my first big A final
Anyway, heres the setup I used. Feel free to give it a try, and let me know your comments.
Carpet Wars 06/07 27t Rd6 Setup
Sufice to say, it would seem that shimming the ball studs forward, combined with the D/D blocks, has solved the mid corner steering issue I had.
To say the least, I'm absolutely ecstatic with todays result...
Cheers
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-11-2007, 07:43 PM   #17824
which is the better carpet car, msx or mre. i am curious so i can get the right one.
OVA Neo. HW, Motiv.
Orange is faster.
Old 03-11-2007, 08:07 PM   #17825
Wing Chun's Avatar
Well Done Ed
Addam
Old 03-11-2007, 08:08 PM   #17826
Burlap's Avatar
Send a message via MSN to Burlap
Both as asphalt cars. The MSX will be easier to convert to the carpet lower deck option (4mm thick compared to the usual 2.5mm) compared to the MRE, which has different spots for the steering posts.
Also putting on the EVO V short arms will help with the car on carpet.
Burlap is offline   Reply With Quote
Old 03-11-2007, 08:13 PM   #17827
Wing Chun's Avatar
Originally Posted by Difuser
TRF it depends on where you are changing it to some degree.
Inboard toe while it helps stabilize the car it also helps unsettle it entry to mid corner when you are running higher degrees of toe. At midcorner initial throttle applications you will see a little more rotation but then settle to more traction as the weight balance fully shifts.
Out board toe has a greater effect onpower as the hubs are driving at a wider stance to the hinge pin/arm/hub combination of inboard toe.
You will need to do a little testing and source some parts but 2d of toe with 1d n the hub and 1d of inboard is not the same as all inboard or all hub toe.
Thank's Difuser
I ran on the weekend and the car with the changes was good but as i powered out I did loose the tail a few times. the problem to was the heat , and man was it hot. I will run it one more time at the next evening meeting and give that a go.
Take care
Addam
Old 03-11-2007, 08:24 PM   #17828
Default setup
heres a great setup for medium-high grip:
Front:
x-ray 25lb spring
60wt w/ 2 hole piston
3rd hole down on shock tower
inner most hole on susp.(short arms)
5 degree caster
1.5 camber
longest front link with 3.75mm shims under inner link
D/D blocks with .5mm shim under rear block and 1mm under front
.5 degree toe out
blue (kinked) swaybar
1mm droop
wheelbase: 4mm behind front arms
HPI pro4 knuckle/bearings with older tamiya axle(orig axle from 415MS)
PARMA magenta with glued edge
Rear:
x-ray 17.5lb spring
40wt w/3hole
3rd hole down on rear shock tower
inner most hole on susp. (short arm)
2 degree camber
0 degree rear hub
2.5 degree rear toe(2.5 when grip comes up)
camber link: inner hole on bulkhead and middle hole on hub w/ 1mm spacer under outer link and .5mm under inner
X/D blocks with .5mm shim under both
wheelbase: 6mm in front of rear arms
yellow swaybar
1.5mm droop
PARMA magenta unglued
Corey "Whitey" Whiteman
TAMIYA- www.tamiya.ca
LRP- www.lrp-electronic.de
Reedy batteries
Protoform- www.pro-lineracing.com
Parma- www.parmapse.com
APS racing- www.aps-racing.net
www.muchhobby.com
TRFwhitey is offline   Reply With Quote
Old 03-11-2007, 08:29 PM   #17829
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by TryHard
Hi guys,
Cheers
Ed
Nice work Ed - well done! I've changed my ackerman to have a 1mm shim now. If the weather holds out I should get to try it tomorrow night. But this sounds very promising indeed.
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 03-11-2007, 08:35 PM   #17830
i only have one real problem. i have not bought the car yet. i am still looking for a good used one to buy or trade for. you guys have been very helpful though in assisting with my decision
OVA Neo. HW, Motiv.
Orange is faster.
Old 03-11-2007, 09:25 PM   #17831
tbeardmore's Avatar
Which way do I turn the bearing holders to tighten the belts? (Towards the back of the car)
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-11-2007, 09:29 PM   #17832
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
to tighten you turn the dot towards the center of the car.
tamiyarcracer is offline   Reply With Quote
Old 03-11-2007, 09:47 PM   #17833
tbeardmore's Avatar
Old 03-12-2007, 01:06 AM   #17834
veecee's Avatar
I don't think so... You better have another look at the instructions - you rotate away from the centre of the car.
Old 03-12-2007, 01:09 AM   #17835
Charles Godwin's Avatar
Nice going Ed, time to get that evoV on ebay now lol .
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
