Old 09-30-2005, 11:00 AM   #10321
Originally Posted by atomic80
What I'd like to know is, when is Tamiya going to release a battery bar for the 415? Any ideas on that? I should be getting my MSX conversion kit from RainbowTEN soon!
Or does anyone know of any aftermarket company that sells the battery bar? I'd prefer Tamiya's since I can't use aftermarket parts in Tamiya races.
So far no plans for a graphite bar. You can make the RDX or X-ray fit easy enough but again it is a no go for TCS. Or use the TB02/TA05 plastic bar with some vertical posts.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 09-30-2005, 11:06 AM   #10322
maxepower's Avatar
Exclamation RE: Battery hold down!
The steering posts off the 414 or the 04 works nice but even though it's all Tamiya parts Fred wouldn't go for it in the TCS races!
I hate tape!
It' cost my son the "A" main in the finals!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 09-30-2005, 11:10 AM   #10323
maxepower's Avatar
Exclamation MSX conversion issues!
Does anybody know if the MSX conversion kit will work on the original 415 lower deck? "Inquiring minds want to know!"
Old 09-30-2005, 11:14 AM   #10324
rtypec's Avatar
Max, more than likely yes. But keep in mind, everything moves up 0.5mm so setups that work with a 2.5mm may be out to lunch with a 3.0mm.
rtypec is offline   Reply With Quote
Old 09-30-2005, 11:15 AM   #10325
Buyer Beware
has anyone built that conversion set yet?
HELLOkitty is offline   Reply With Quote
Old 09-30-2005, 11:58 AM   #10326
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I just ordered some 46mm steel swing shafts. So the spool troubles should be solved.
Man, i want an MSX conversion so bad
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 09-30-2005, 12:03 PM   #10327
Martin Crisp's Avatar
Default orig 415 lower chassis with msx
Actually I decided to mount my original 415 lower deck instead of the ms chassis yesterday as my msx conversion kit just arrived. I did this for two reasons. The original 415 chassis is obviously a little stiffer but it can also accomodate the original 415 suspension which is strong and the steering knuckle can handle foam tires unlike the lw steering knuckle we currently have. Although it is not as stiff as the 4mm prototype chassis used at vegas the car is very stiff with this chassis.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 09-30-2005, 02:10 PM   #10328
V12
V12's Avatar
Martin
Using the same 3mm chassis do you think the MSX bulkheads und upperdeck are resulting in a stiffer car than with the original bulkheads and 3 part upperdeck?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 09-30-2005, 02:45 PM   #10329
Trader Rating: 23 (100%+)
Does anyone have a Foam roll-out chart that they would like to share ?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 09-30-2005, 03:38 PM   #10330
Default v12
v12 - I still think the original 415 will be stiffer than the msx with the orig 3mm 415 chassis. However the msx does have a lower CG than the 415 and it seems stiff enough to me, although I would use the 4mm chassis if Tamiya decides to release it.
M
Martin Crisp
Old 09-30-2005, 03:49 PM   #10331
V12
V12's Avatar
M
Thanks, that is what I wanted to hear. So the MSX configuration should be better for rubber tires on a low to mediumgrip carpet than the original 415. Also seems to me the MSX will have less chassis tweak.
Old 09-30-2005, 04:42 PM   #10332
Herc Driver's Avatar
Hey could you guys (I know its possibly not the appropriate thread for vs. topics) tell me which is better for stock racing the EVO IV or the 415? The both have the same suspension right? I would guess the EVO would be a more "free" car...but of course thats why I'm asking.
Paul
Herc Driver is offline   Reply With Quote
Old 09-30-2005, 07:00 PM   #10333
GT Racer's Avatar
Fixed up mine 2 days ago. Had a run on it yesterday. Having almost identical setup as the MS. The car really handles so much better than the MS.Very fast cornering speed and on throttle out of corners, very stable car due to the low CG.
The 2 steering post needs some shimming though. Overall, the car is just beautiful!
GT Racer is offline   Reply With Quote
Old 09-30-2005, 07:55 PM   #10334
JimmyMac's Avatar
EvoIV has a different suspension than the 415, but the same as the 415MS. The 415 has a smoother cornering and transition driving feel to it. The Evo is more direct. I prefer the Evo with the Team Bomber main shaft instead of the aluminum one. For me it absorbs some of the drivetrain shock and lessens the twitchy feeling a tad. Bang for the buck though... 415 has it hands down. It comes with all the sway bars and some rear toe blocks. The Evo doesn't. I also feel that the Evo breaks free more so than the 415. So that can be a plus or minus pending what you are looking for in a setup. I dunno.. I'm just babbling.. hehe... I'm currently racing my EvoIV in Stock and it's doin pretty good.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-30-2005, 08:24 PM   #10335
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
someone sell me their spare 415 for a good price.
OUT
Keith Billanti is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
