Old 11-08-2006, 03:55 AM   #16321
Wing Chun's Avatar
Default My custom fan
Hi Guy's
I thought I would post some picture's of my home make Dual Fan for Modified Motor's I Built.Because I race modified and wanted to keep me motor nice and cool. I set this up for my Orion 8 turn single.
First i bought 2 x 3 racing heat sink's, I decided to run 2 x MR fan's.
I cut one of the blue extention's in half that allow's you to have the fan over the end bell of the motor. I then bent it so i could have the second fan blowing directly onto the endbell.To get a nice clean bend I used a large drill bit and bent the end if the fan extention over it.I have both fan's blowing onto the endbell. I added a few Tamiya anodized spacer's and presto.
after a 5 minute with the old fan the lowest temp I could get was 66.9 degree's
with the new fan it after 5 minute's was 52.8 degree's.
What do you think of it.
Addam smith
Tamiya TRF415-s-custom-dual-fan-003-small-.jpg   Tamiya TRF415-s-custom-dual-fan-004-small-.jpg   Tamiya TRF415-s-custom-dual-fan-005-small-.jpg
Wing Chun is offline   Reply With Quote
Old 11-08-2006, 05:07 AM   #16322
bender's Avatar
Nice
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 11-08-2006, 06:32 AM   #16323
Mason's Avatar
Originally Posted by ljohnson
Measuring says 34mm on the 415 and 25 mm on the MSX, so nine mm lower.
thx. is the (front) inner camber link mount at the same height of the deck on the msx/mre, higher or lower? I'm trying to modify reinhard's 05 iic setup backwards a bit. Still using standard chassis so i'll need to move the weight back like the 4mm chassis, and if there's any other things that I'm aware of I'm sure somebody will chime in.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-08-2006, 08:55 AM   #16324
rtypec's Avatar
Originally Posted by maxepower
Fellow racers,
I'm looking for a good set-up for carpet using rubber tires. RP's mostly.
Try Mr. Martin Crisp's setup. Also, if EJ Evans can chime in, his setup is good too.
rtypec is offline   Reply With Quote
Old 11-08-2006, 10:06 AM   #16325
kentech's Avatar
Originally Posted by kentech
TRF415MSXX (?) Coming February 2007...
Check my blog for a bit more information:
http://kentech.blogs.se
Not sure on the name but expect a new kit in February.
This info is coming from a what I would consider reliable source.
Now on Tamiyas website. The MSXX will be displayed at the Tamiya Fair/Tamiya Cup World Finals 18-19 November in Japan. That is the same weekend as JMRCA Nationals.
New product announcement
RC-related commodity
■TRF415MSXX
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-08-2006, 11:18 AM   #16326
maxepower's Avatar
Exclamation Carpet set-up
Mr Evan's if you read this you can PM me your set-up if you want!
Thanks in advance!
Max
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 11-08-2006, 11:27 AM   #16327
Charles Godwin's Avatar
Another new car? This is a bit strange considering the MRE hasn't been out that long.
Charles
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 11-08-2006, 01:30 PM   #16328
I think TRF415MSXX is to race with 4 cells.
trf_racer is offline   Reply With Quote
Old 11-08-2006, 04:07 PM   #16329
WRXTC's Avatar
Is it possible to use 2 standard centre pulleys untill I do the TA-05 conversion? The standard centre pulley is locked I believe and doesn't look to be any bigger than the oneway centre pulley so I should be able to fit a standard centre pulley next to the one that comes with the kit?
Or will they not fit?
WRXTC is offline   Reply With Quote
Old 11-08-2006, 04:35 PM   #16330
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
you can use 2 locked pulleys.... but you need to file a flat spot on the center shaft. i had done it long ago, before the 1-piece pulley was available.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-08-2006, 04:37 PM   #16331
stuey's Avatar
i take it you are thinking of replacing the centre one way i'm not sure without looking if they will fit but don't forget there is on two flats on the layshaft one for the spur gear mount one for one fixed pully
stuey is offline   Reply With Quote
Old 11-08-2006, 04:48 PM   #16332
WRXTC's Avatar
Thanks Guys. Easy to just file a flat spot on the shaft and wait till I need some more parts from rc_champ and order the conversion kit or fixed pulley.
Old 11-08-2006, 07:55 PM   #16333
Charles
Most probably a 4 cell version for the MRE....
But the thought of a new version of the MSX is coming out after not long I bought my MRE...Sux....
Ben.C is offline   Reply With Quote
Old 11-08-2006, 09:54 PM   #16334
Tsquare's Avatar
Not that surprising, Tamiya is always thinking!
Tsquare is offline   Reply With Quote
Old 11-08-2006, 10:16 PM   #16335
Just got the MRX front oneway housing 53947. Should I use 53936 TA05 wide pitch front oneway pulley 36T with it? thanks
ioxqq is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
