Old 03-12-2007, 03:34 PM   #17836
tbeardmore's Avatar
Originally Posted by veecee
I don't think so... You better have another look at the instructions - you rotate away from the centre of the car.
Yep- you're right - I figured that out last night...
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 03-13-2007, 09:41 AM   #17837
Default which 415 is best?
I'm looking to a belt drive TC and looking at the 415 but not sure which model to shoot for. What are the good and bad, as well as the differences (other than price) between the MS, MSX, MRE, MSXX, and the Refine 2? Which is best for foam/carpet racing on a small track? I'll be running it in a 4300 brushless/lipo class. Thanks for any info you can give.
LJae is offline   Reply With Quote
Old 03-13-2007, 12:42 PM   #17838
stuey's Avatar
can sombody measure me a tamiya 415 ms msx mre msxx rear diff for me please i need to know the measurment from the most inner part where the bearing sits to the same place on the oposite outdrive with the diff compleate
thanks guys
IN METRIC
stuey is offline   Reply With Quote
Old 03-13-2007, 03:26 PM   #17839
Tsquare's Avatar
The original TRF415 is a very good carpet car, mainly because it has a stiffer chassis then the following models. The MS is strictly for asphat, the MSX(same as the refine 2), is a good carpet choice, because you can get a 4MM thick lower chassis for the increased stiffness needed for carpet, in addition, the MSX has the easy diff access front and rear bulkheads, that the original TRF415 didn't have. The MRE and MSXX have the improved steering and more efficient drive-train.
Tsquare is offline   Reply With Quote
Old 03-13-2007, 04:26 PM   #17840
Hello
Can you tell me what tuning do i need to buy to make my TRF415MSX MRE fast on the carpet track on rubber tires. I already have piston with 3 holes. Set of springs including very hard and ultra hard (is it good idea to use very hard and ultra hard springs on carpet with rubber?). I also have 6mm silver hex. I have one-way and spool.
What about suspension, should i use arms 53928? I heard that they are better for carpet.
What next?
Tral is offline   Reply With Quote
Old 03-13-2007, 05:19 PM   #17841
TryHard's Avatar
Originally Posted by Tral
Hello
What next?
Hi Tral,
Most people use just the White and Blue Tamiya springs on carpet with rubbers. I've also found the Short suspension arms very good on carpet.
A one-way unit is a good idea as well, I personally run both front and centre one-ways. Have a look at my setup from further up the page, I found that really good this past weekend.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 03-13-2007, 05:21 PM   #17842
TRF415boy's Avatar
Hello
What next?
On Carpet with rubber you want to stick to the tamiya white on front and blue on the rear.
Basically I'd recommend to try the setup TryHard has posted on this same page as it's a setup that's been worked on for some time. And if there's enough grip i'd stick to a one way.
TRF415boy is offline   Reply With Quote
Old 03-14-2007, 07:57 PM   #17843
Tek Nickal's Avatar
Hey does anyone know the part number for the TA05 steel spool outdrives that fit the 415 spool?
Tek Nickal is offline   Reply With Quote
Old 03-14-2007, 09:36 PM   #17844
speed8081's Avatar
What is the part number for MRE belt (front & rear)?
Can MRE use 53706 & 53707 low friction belt ?
Thanks.
speed8081 is offline   Reply With Quote
Old 03-15-2007, 01:18 AM   #17845
tamiyarcracer's Avatar
Send a message via Yahoo to tamiyarcracer
Thanks.
http://www.tamiya.com/japan/rc/manuals.htm
Look up the part #'s in the manual.
tamiyarcracer is offline   Reply With Quote
Old 03-15-2007, 01:21 AM   #17846
53877 is the only way I know
Old 03-15-2007, 06:08 AM   #17847
do ta05 diffs and centre pully fit the 415?? because im gointo to be drifting my 415 but it has one ways cant stand em lol so yer do they fit?????
Mr.Roboto is offline   Reply With Quote
Old 03-15-2007, 08:10 AM   #17848
stuey's Avatar
thanks guys
IN METRIC
any body
Old 03-15-2007, 08:33 AM   #17849
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
thanks guys
IN METRIC
are you trying to get it to work on the cyclone?
Old 03-15-2007, 09:01 AM   #17850
Martin Crisp's Avatar
Default I'm out
Hey,
Just wanted to let my fellow 415 drivers know that I have decided to leave the hobby. It's been a lot of fun, but due to the health affects of the chemicals we currently use (eg. traction compounds, etc) I have decided to get out. Some of you may have already read my thread on traction compound health issues already. I might come back if thngs are done to reduce or eliminate exposure to these chemicals, but that is unknown at this time.
Anyway, good luck and represent tamiya with pride.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
