Old 10-08-2007, 02:55 PM   #19321
AWK
AWK's Avatar
Originally Posted by surrealmaterial View Post
you should wait for the 416
I might drive one of those as well, but someone at the Tamiya offices will have one I can take a look at. I would get the MSXX MRE for a shelf piece anyways.
AWK is offline   Reply With Quote
Old 10-08-2007, 03:44 PM   #19322
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
can i use my original oneway pulley with the spool?
cheers
you can reuse the plastic pulley but not the Aluminum one with the one-way bearing in it. You need one more plastic pulley for the center shaft.
Racing4Evo is offline   Reply With Quote
Old 10-08-2007, 05:56 PM   #19323
miccal's Avatar
Trader Rating: 23 (100%+)
I have a question for the people who run the original TRF415MSX. In the picture attached the part BD1 (5 by 7 by 9 mm spacer) goes above the steering arms and slips over the top of the steering posts. When you attach the upper deck part BP4 and screw it down, do the steering arms and the spacer have much vertical play on the steering posts? Mine seems to move up and down a little.
miccal is offline   Reply With Quote
Old 10-08-2007, 10:19 PM   #19324
infokiz's Avatar
Yes the play is normal and will get worse with wear. you can use some shims to take it out just make sure that you don't make it to tight.
infokiz is offline   Reply With Quote
Old 10-09-2007, 04:15 AM   #19325
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Originally Posted by skiv View Post
ok thanks for the advice ill have a look at the convertion before i go out and buy lipos.
MSXX with Li-Po, brushless motor and ESC and an X-ray battery holder and a foot
buboy28 is offline   Reply With Quote
Old 10-09-2007, 01:39 PM   #19326
nice one thanks for the pic looks awsome.
ive just rebuilt my msxx because it was handleing like a pig compared to my old msx.
ive got the same setup as i had on my msx and it just spins out on corners no corner speed.
i havent noticed to many diferences between the two cars so i dont understand how it reacts so much different.
ive noticed that the balance from one side of the car to the other is quite a bit diferent so ive added some weight on the motor side to try and even it out.
iam begining to think that i should have stuck with my old msx
skiv is offline   Reply With Quote
Old 10-09-2007, 02:12 PM   #19327
TryHard's Avatar
Skiv,
The steering setup of the MSXX requires a slightly different setup to your MSX.
I would recomend starting off at the kit setup first, then making adjustments.
Can you post your current setup, and what surface etc your running?
Hopefully we can all help out
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-09-2007, 04:17 PM   #19328
iam raceing at my local club eastbourne tomorow night if its dry so ill see how it goes now i rebuilt it.
is the steering going to affect the setup that much?
i think i meet you there tryhard when the stcc was on i got 3rd in stock.
ill post my setup tomorow as the cars all packed up in the shed its dark out there lol.
Old 10-09-2007, 04:49 PM   #19329
TryHard's Avatar
Haha, you probably did meet me... didn't do too well myself, but I was running a Type-R that weekend. Actually was using the MRE for a bit of practise/fun that weekend...Car wasn't too different from kit if iirc, though that was with a 7x1 in!
The setup shouldn't be massively different, but then again, depends how you had the MSX setup...
Regards
Ed
Old 10-09-2007, 09:46 PM   #19330
Centerfire's Avatar
Trader Rating: 6 (88%+)
Try Hard :
What is the advantage of using 16 Balls Diff Modification compared to 8 Balls Diff Stock of MRE in Running stock 23T? Does it Really have Advantage?? What's the purpose of that modification? I tried Running Both Diffs but i don't see any difference. Thanks sir!
Centerfire is offline   Reply With Quote
Old 10-10-2007, 12:57 AM   #19331
TryHard's Avatar
TBH... I didn't find an advantage when running stock. I've gone back to the standard 9balll MRE diff for the moment, as it's lighter.
However, for thoose running Modified, certainly should be an advantage in terms of reduced wear and tear on the parts, simply as there are more balls to take the pressure exerted on the diff high powered mod/BL motors.
HiH
Ed
Old 10-10-2007, 08:29 AM   #19332
Centerfire's Avatar
HiH
Ed
Hi Ed, Thank you! I needed that..
Old 10-12-2007, 01:54 AM   #19333
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
can you put the MRE center shaft in the msx?
cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 10-12-2007, 04:32 AM   #19334
TryHard's Avatar
cheers
Yes, although you will also need the plastic pulleys (16t or 18t your pick). You'll also and need to turn the bearing holders around, as the bearings are held captive by the shaft pushing them into the holder.
HiH
Ed
Old 10-12-2007, 05:30 AM   #19335
thanks, but if i choose the 18t pulleys would i be able to run my original belts? (also running 36t white pulleys)
Castle Hill Raceway
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
