Tekin RS ESC sensored >
Old 07-09-2009, 02:16 PM
  #4801
Originally Posted by hound_dogs_01
Guys I'm having a hesitation problem w/ my RS pro... I can slam the throttle and its a good second to 2 seconds before the car takes off.... the speed control sees me slam the throttle and sees it all the lights light up... the motor is a novak 21.5 running sensored only mode and i confirmed the sensor wire is plugged in correctly.... I rebinded my spektrum, re programed the speed control back to defualt settings and its still there and re-did the full throttle neutral and full brake settings as well.......
I have version 199 software...
Alex
I had the same issue last month...basically the ESC is acting like it there is no sensor wire plugged in. It could be a bad sensor wire or just dirt in one of the sensors. I took my motor apart and sprayed it out really good and it has been working fine ever since.
InspGadgt is offline
Old 07-09-2009, 02:29 PM
  #4802
hound_dogs_01's Avatar
Trader Rating: 16 (100%+)
thanks Ill try that... mabe my sensor wire is pluged in backwards who knows...
How hot should my rs pro get? It temped 130 last night...
Alex
hound_dogs_01 is offline
Old 07-09-2009, 02:33 PM
  #4803
Krio's Avatar
Trader Rating: 159 (99%+)
Alex
Temping the esc is not the best way to determine if you are pushing it. If you leave the throttle at neutral and watch the leds you should notice it blipping from the lone center led to a line of leds starting at the left. Count how many leds light up and that tells you how hot the esc is internally. Unless you start seeing any more than 6 leds regularly you have nothing to worry about.
Krio is offline
Old 07-09-2009, 02:38 PM
  #4804
espresso1967's Avatar
Trader Rating: 18 (100%+)
Thanks, I always have an open mind and will conider it depending how the mod class does.
Originally Posted by Cpt.America
Actually, a voltage booster is a GREAT way of doing it. Zero maintenance, Zero setup, and they don't weigh a thing. Also... no room on a WGT chassis for electronics? There is ALL KINDS of room... I have 10x the amount of free space on my WGT than I do my sedan. I literally have room for 4 or 5 more boosters
Either way.. in the future, when you change your mind and eventually run it, you will see the RS' 1s checkbox is a nice feature to have on the speedo.
espresso1967 is offline
Old 07-09-2009, 02:43 PM
  #4805
OK thank krio... I didnt know that!!!! I never saw more than 1 to 3 lights on when in neutral...
But when I NAIL the throttle to wide open throttle all the lights on the ESC show up then 2 seconds later the motor spools up
CPTamerica - I have never taken the motor apart, it was brand new up until Tuesday... before I left last night I reset the ESC to default settings and it helped some... What do i clean the inside of the moroe out with?
Alex
Old 07-09-2009, 02:47 PM
  #4806
Trader Rating: 88 (100%+)
Hey hound, the temp light will flash while its in nuetral. I stood in my driveway last Friday evening and watched it flash in my T4, and thats with the body on. I had a 13.5 installed and the motor temp was about 180 couple. The temp on the speedo was only flashing one light. Hope this helps.
Ken
MUDVAYNE is offline
Old 07-09-2009, 02:48 PM
  #4807
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
i use just air and blow it out
20 SMOKE is offline
Old 07-09-2009, 02:59 PM
  #4808
Team Tekin
Randy_Pike's Avatar
Relax guys. I want you to have the best software that we can offer. We're all racers here and we want Tekin to be the best.
I will post up when 200 is released.
Randy_Pike is offline
Old 07-09-2009, 04:54 PM
  #4809
Senna Racing's Avatar
randy do you know of any one that has used the lrp 11x 17.5 with the tekin rs
Senna Racing is offline
Old 07-09-2009, 06:13 PM
  #4810
YmeBP's Avatar
Trader Rating: 32 (100%+)
mmmmm 200 i think i just made a mess ..
YmeBP is offline
Old 07-09-2009, 06:15 PM
  #4811
Team Tekin
Randy_Pike's Avatar
Senna, yes. They were running the LRP in the middle timing position. They ran the same setup that was being used by another running our 17.5. Both cars were fast...they were in seperate heats though.
Old 07-09-2009, 07:50 PM
  #4812
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Alex
compressed air! I also clean in and all around the inside underneither the ends, like around the bearings. And also put a tiny drop of light bearing oil into the bearing race... and then wipe the outside of the bearing off with a towel... then reassemble.
Cpt.America is offline
Old 07-09-2009, 07:51 PM
  #4813
thanks for that
Old 07-09-2009, 10:08 PM
  #4814
randy, need your help with gearing the tc5 with tekin 10.5. and RS. i m getting pulled on the straigt by 13.5s
what 48 p and 64 p would be a good start.
JdogL is offline
Old 07-10-2009, 03:47 AM
  #4815
was woundering what is a good strat out gearinfg for the lrp 11x 17.5
And also what profile i updated todaty to 198
Does it matter what version you use for differant classes
