Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 04-26-2004, 10:40 PM
  #8026
DOMOisCOOL's Avatar
Originally posted by Aku-Man
Looks like Shooter Graphite Main Shaft. Are they the same?
http://precisionrc.com/product/shooter/sd.htm#ms
Is that store located overseas or in the USA? I've been looking for one of those battery braces.
DOMOisCOOL is offline
Old 04-26-2004, 10:46 PM
  #8027
Tek Nickal's Avatar
Overseas.
Tek Nickal is offline
Old 04-26-2004, 10:59 PM
  #8028
yeah it looks identicle
shortygy is offline
Old 04-27-2004, 05:24 AM
  #8029
Trader Rating: 35 (100%+)
With the exception of the ends, the shaft portion looks the same as the Yokomo shaft. For those that had Yokomo shafts that broke, where did they break? Was it a clean break (snap), or did the shaft splinter?
I was expecting the Fukuyama center shaft to be like the Bomber shaft which is a hollow carbon fiber shaft.
Geppetto is offline
Old 04-27-2004, 05:40 AM
  #8030
johnbull's Avatar
Hi friends. Greetings from Malta.
GEPPETTO.
My Yokomo graphite shaft splintered. It actually looks all right externally but if you hold both ends and twist it will twist through 180 degrees. Definately on the way out.
ALLOY DRIVE SHAFTS.
We all agree that the blue alloy shafts are lightest and we would all like to use them, but they wear too much.
Well I think I've found a solution. I have managed to make rubber dust covers for the CVD ends. They are now packed with grease and hopefully the grease will stay in. All they are is a piece of shrink tubing. Actually 2 pieces each. Here's how it's done.
Shrink a piece approx. 6mm long on the outer end of the shaft, just near the ball end.
Assemble the CVD.
Cut a piece of shrink tube about 1.5cm long and slide it over the CVD. Leave an overhang of 1 to 2 mm on the hub end.
Now heat it. When it shrinks that 2mm will hold it all in place and stop it from sliding out.
You may need to dremel the hub a bit outside the inner bearing just to give the wholeassembly more space.
As I use MR4 Special front hubs it wasn't a problem with mine because these hubs have much bigger bearings, but I did dremel a bit on the rear.
Wouldn't it be nice if they made rear hubs with the big bearings too.
Regards
Joe from sunny Malta.
johnbull is offline
Old 04-27-2004, 07:55 AM
  #8031
lem2's Avatar
Default johnbull
could you possibly post a picture?
Thanks!
lem2 is offline
Old 04-27-2004, 08:07 AM
  #8032
Registered User
ritchie's Avatar
i'm confused, are you talking about the long center shaft or the cvd shaft. my car doesn't have cvd's any where on it.
ritchie is offline
Old 04-27-2004, 09:30 AM
  #8033
Horatio's Avatar
If your car is an SD, it will have 4 CVD (constant velocity) driveshafts - one in each corner. Unless you've taken them off in favour of old-style universal joints!
Johnbulls idea is basically a way of making a boot cover for the CVD joint in order to prevent premature wear - especially on the lighter alloy items.
Horatio is offline
Old 04-27-2004, 06:31 PM
  #8034
Matt Howard's Avatar
The new graphite gears should be in the states in a couple of weeks. Seeing as how the graphite parts are proving to be more durable on the suspension, the gears "should" be a bit more durable and since they're stiffer will be more efficient.
Matt Howard is offline
Old 04-27-2004, 09:40 PM
  #8035
In late May they are coming out with new HD Graphite Arms.
pops is offline
Old 04-27-2004, 09:49 PM
  #8036
pops is offline
Old 04-27-2004, 10:01 PM
  #8037
Tek Nickal's Avatar
SWEET, now the front and rears are DIFFERENT for added strength.
Old 04-27-2004, 10:12 PM
  #8038
lem2's Avatar
Default Nice arms
hope they reach our shores soon.
lem2 is offline
Old 04-28-2004, 12:26 AM
  #8039
johnbull's Avatar
Thank goodness for that.
Does anyone have any part numbers?
Regards
johnbull is offline
Old 04-28-2004, 01:24 AM
  #8040
utieh's Avatar
Are those new arms only for the rear, is it just the shape which is changing, I mean is there any new mounting holes or differences in their geometry?
utieh is offline
