Yokomo MR-4TC SD
#7997
Cool thanks Russ, I'll see you guys on Saturday.
#7998
Originally posted by pops
Yeah, it was crap or you wouldn't have given it to me. After I worked a little magic on it, it came to life.
Hey everybody has been ahead of that guy more than once.
#7999
is there any quick fix that will cure the diff bolt snapping problem on the SD
#8000
Very simple, don't crash. Diff bolt snapping? Never had that problem. If it comes off, then use thread lock. Or does the whole diff screw snap?
#8001
the screw snap into 2 pieces, a piece at each outdirve
#8002
What our your thought on the CG chassis?
Also want is a good setup for an asphalt track that is treated with pop?
Curruntly I'm running the SSG chassis with red up front 50W, and blue in the back 40W. Both are associated springs. Take OFF 27-32....
#8003
other people have talked about this. You can try and find a hardened bolt somewhere. I think someone said it was a 2.6 mm size. I dont relaly understand how only a few people have this problem though....?
#8004
#8005
maybe you guys are snapping diff screws because u are running ur siffs too loose or too tight... just a thought
#8006
#8007
Fukuyama has a graphite center shaft for the SD coming out soon. I ran it this past weekend with no signes of splitting like the yokomo one. It's a bit lighter than even the Tobee center shaft and looks trick. I don't know exactly when it's coming out but you guys need to start bugging Dan at Fukuyama to start selling them, they're worth it.
#8008
Sounds sweet, how many grams is it?
#8010
If you put an 8 gram weight on one hand, and a 8 gram weight on the other, it will feel different depending on what hand you use more, what hand you use more means that that side of the brain works more, giving you an unaccurate measurment. Just an thought.
