Yokomo MR-4TC SD
#8176
Originally posted by Jeff Werner
Pops- when the bearings are going out what are the warning signs or how are you testing them to see if they need replaced.
Jeff
Jeff
I can hear my bearings when I spin the wheels...
#8177
Originally posted by yodace
My yok is only 2 race days old too..
#8179
Re: Re: question
Originally posted by lem2
anyone?
anyone?
#8180
Matt and Pops...wanted to talk droop. What are your thoughts on initial starting spots for front and rear droop on the CGM? What changes are you looking at obtaining when running less droop (Higher number on guage)?
I am still trying to dial in my Yok...one run it is spooky fast then it gets unstable at times and am trying to get all the info I can...
Jeff
Jeff
#8181
pops,
I can hear the bearings on both the front and rear of the car...
I think its the outdrive bearings...
Do u suggest taking the hub/outdrive bearings out and cleaning them?
Do suggest taking the hub/outdrive bearings out and cleaning them ever 2-3 race days?
#8182
pops
Originally posted by pops
I don't know, why don't you take a steering knuckle from a MR4-TC and see if it fits? The C hubs will not fit unless you Dremel the heck out of them. I like the new Graphite better with the new lightweight kingpins. The Suzuki ones can bend (or brake) with a hard hit, and bind your steering. But, they do look pretty cool!
Peace and Happy Racing! Lem
#8183
pops,
I can hear on both the front and rear of the car...
Do suggest taking the hub/outdrive bearings out and cleaning them?
pops,
#8184
Registered User
How do you guys take off the seals to clean up the bearings?
#8185
#8186
Jeff
Jeff
#8187
Ride Height Help!
I'm having serious trouble adjusting the ride height on my SD Black, after adding a rear shock tower to the front of my car. I'm using the same mounting locations used by Chris T, and Mo on their setup sheets, but I just can't seem to lower the chassis.
Last week I broke my front shock tower, so I decided to place a rear one on the front. As it turns out, this change completely change the handling characteristics of my car and I had another bad weekend of racing.
I can't seem to lower the ride height. I need HELP!!!
Also, question on setting droop... Do you guys adjust droop with the shocks removed (detached from "A" arms)?
Thnx
Thnx
#8188
Re: Re: Re: Home made Fixed Spool
Originally posted by Matt Howard
Losi sells spool pads that are sandpaper discs, I think they cost $1.50. Take apart your diff and clean all the diff lube off of the gear and diff rings. Put the spool pads on top of your diff rings with the sandpaper side out, leave all the diff balls out of the diff but keep the thrust bearings and spring in and screw everything down tight. You now have a spool. I've been running mine like this for over a month now with barely any wear.
Will try it out! Appreciate the info!
#8189
Originally posted by utieh
what about the quality of the shooter's?
I saw it at $20 in a shop in HK.
#8190
Re: Ride Height Help!
Thnx
Thnx
I check the droop with the shocks attached. If you do it without the shocks attached and the shocks are too short, you will change droop. So you could do it either way, but check it again after the shocks are re-installed.
