Like Tree478Likes
TLR 22 4.0
    Hide Wikipost
Old 03-22-2017, 06:19 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 4.0
Last edit by: Matt M.
22-4.0 Wiki
Print Wikipost
Old 06-05-2017, 05:57 PM
  #721
Originally Posted by jpcopeland1
Stock or mod? In stock I didn't like how much overall traction it gave on high bite clay (it was a ton). I ended up going with a 26gram weight plate under the lipo to lock in the rear, but not to the point that it was with the brass hinge pin brace, but now that I am about to add in the SR diff and drive shafts I will probably put it back in cause the car will be way under weight, and I will reintroduce mid corner traction breaks at the apex of 180 style turns and long bumpy sweepers. IF running mod, it's pretty much a must have to remove the possibility of completely losing rear grip if you get out of shape off a jump, or get out of the race line and into the dusty stuff.
I looked all over the place and no one has that brass parts in stock. I guess I'll need to wait for them to come back into stock.
John Q is offline
Old 06-05-2017, 06:35 PM
  #722
Trader Rating: 25 (100%+)
The Exotek Brass C block works great.
22 4.0/3.0 BRASS REAR/FRONT LRC HANGER, BLACK 30GR - Exotek Racing
chevmaro is offline
Old 06-05-2017, 06:46 PM
  #723
Originally Posted by Jason B
Could you describe your build/break-in process for the diff? This seems to be happening a lot more than usual, so just trying to get a handle on why for my own education / peace of mind.
I couldn't get the diff to break in right, tried a second time by flipping rings, cleaning out grease. Same thing. It was smooth for a day both times. I didn't have the outdrive issue other's have had either. Some at my track also having diff issues and some not. Not sure what the deal is.
I hate buying extra parts for new kits, but bought an MIP superdiff for $28 and the car now drives fantastic. If I buy a second kit I would go the same route.
chevmaro is offline
Old 06-05-2017, 07:04 PM
  #724
Originally Posted by chevmaro
Mine fit perfect on the 3.0 and my second fits perfect on the 4.0.
Amain has them in stock too.
silverbugeye is offline
Old 06-05-2017, 09:18 PM
  #725
froggie22's Avatar
Just built my 22 4.0.. Flawless build as usual.. I didn't pick up the stanley knife, reamers or dremel once...
I can't wait to get it on the track.
froggie22 is offline
Old 06-05-2017, 09:21 PM
  #726
Pinkz's Avatar
if i run on ozite, what do i what HRC ot LRC?
Pinkz is offline
Old 06-06-2017, 04:25 AM
  #727
jonbrown's Avatar
I'd run hrc on carpet/astro
jonbrown is offline
Old 06-06-2017, 05:09 AM
  #728
Pistol123's Avatar
As I understand it the HRC is used to correct the roll centre when using lower ride heights. Frank suggested I use the HRC, +3 rear hubs and Diff for a 20/21mm ride height as a starting point if that helps.
The above is for grass and bumpy astro, I think the HRC is really useful as it is allowing me to use the soft (kit) springs without getting lots lean. I have also tried stiffer springs and found they don't provide the same improvement compared with my previous car (DEX210).
charvel74 likes this.
Pistol123 is offline
Old 06-06-2017, 01:19 PM
  #729
Originally Posted by Davidka
I just went to AE as well. I'm not quite ready to go with a laydown transmission yet, but I was unwilling to invest more than 1/2 the cost of the kit to convert my 22 3.0 should that day come. I really like the B6d so far, so no regrets.
The 22-3 with the lay down works awesome
johnnygonny is offline
Old 06-06-2017, 10:04 PM
  #730
Trader Rating: 14 (100%+)
Originally Posted by DG Designs
What do you sand? Getting ready to pick one up for my SR
Anyone?
DG Designs is offline
Old 06-06-2017, 10:17 PM
  #731
lbckevin's Avatar
Trader Rating: 107 (99%+)
I just got my SR diff from Horizon on ebay and there was no need to sand anything. It fits great.
lbckevin is offline
Old 06-07-2017, 12:13 PM
  #732
pekow91's Avatar
Trader Rating: 45 (100%+)
Was going to pick up a kit today. Anyone have a good outdoor setup for a hard pack dirt track that has a loose layer on top? Also any option parts I should keep in mind. Sorry for the noob questions but skimmed through the previous messages and didnt see this being answered.
pekow91 is offline
Old 06-07-2017, 01:15 PM
  #733
Casper's Avatar
Trader Rating: 34 (100%+)
Buggy does not really require any upgrades. I would suggest alum servo horn and possible the A/B horn. Otherwise the car is pretty outfitted.
I would start with the kit setup and appropriate tires.
pekow91 likes this.
Casper is offline
Old 06-07-2017, 01:20 PM
  #734
Trader Rating: 166 (100%+)
Agreed for the most part, but if he is gonna on hard packed dirt with a loose top coat, some weight for the rear may need to be used.
pekow91 likes this.
jpcopeland1 is offline
Old 06-07-2017, 01:22 PM
  #735
Yeah, it's been a month since they have been available. Still getting a date of June 29th for them to come in. Kind of the reason I left AE was lack of upgrade parts. Seems to have hit every manufacturer. (Edit), I have decided to get the Exotek parts out of sheer necessity for mod. In stock I just needed to add the under lipo weight plate, and traction fore and aft was just fine.
