TLR 22 4.0
#1471
Apparently there has been people having problems with the SR axels snapping and quite a few people have been talking about the outdrives breaking. I have about 25-30 battery packs through my SR now and I drive VERY hard and run on high bite clay and, knock on wood, I haven’t experienced any of those problems.
#1472
What is everyone running for stock gearing ? I just changed my main gear to a Schelle Racing Schelle Nova Slipper Assembly with a 69 tooth main gear. Now to find the proper Pinion..
#1473
But most people are between 69/28-30
#1474
Had my first race yesterday after a 7 month break with my new 4.0.
Running 13.5 blinky, built the box carpet setup besides the sway bars,AE purple springs front,AE gray rear,Schumacher cut staggers front,mini pin yellow rear.
The car was great,very easy to drive.Qualified 7 out of 21,finished 6th overall.
Only Losi in the field.
#1476
Does anybody have a review on the stiffezel front wheels? I would be using them at ocrc stock class, not sure if they would be a benefit.
#1477
i race on carpet and it felt like they smoothed mid-corner steering and perhaps took away a bit of front end bite.
if you have a load of wheels i wouldn't go out of my way to buy them, but if you do happen to be after wheels you should try them, i will be exclusively getting them going forward
#1478
Curious to see what you guys think of running a front wing....
Pros, cons, etc... If you've run one, do you notice a difference? If so, which ones have you ran?
#1479
How's this buggy on outdoor dirt with holeshots. Only have a laydown. Feel like I'd need to add steering g. How's the grip in 3 gear standup?
#1480
I am wanting to install the MIP Pucks 17.5 Drive System in my 22 4.0 build. Does anyone have a part number for the kit for the 4.0. everything I pull up refers back to the 3.0
#1482
Gearing depends on track. I was mostly between 27 and 29 tooth pinion for small tracks. Most carpet tracks in the states tend to be small.
#1483
