TLR 22 4.0
#692
Im not doubting that it has worked out for you and others, but for me there is no way it will work with even length links.
I have already built the car and set the steering and the only way it will work is with horn centered. Ive had it all apart and double checked everything and its built correctly.
I am using the aluminium steering rack and posts so im not sure if that would be causing this?
#695
If you bought it lately from Horizon, then you are good. If your local hobby shop had it in stock for a few months... then it may bind
#696
How do you know if you have the revised diff without taking it out of the bag. Some stores will not accept open merchandise.
#697
Servos don't travel in a straight line, they arc in a circle left/right, ideally you want that arc to be the same left/right.
#698
Depends on the car, but generally your steering curves will be different left/right from center to full lock if you don't set up your steering correctly. This is most obvious when your EPAs are noticeably different left/right at full travel.
I imagine with the off centre horn the endpoints would hypothetically be even left to right for full throw, but i cannot get that to work with equal length links.
Ive tried shortening the draglink to 31 and that is a little better, anything below 31 and it can over extend and lock out.
#699
"equal length links."
I assume you are talking about the steering turnbuckles? You use these to set toe, it has nothing to do with centering your steering. Measure them out per the manual and make sure they are the same. Install the horn as close to straight up and down as possible, set trim, and done.
#700
#701
#702
Exactly! That is why i am asking the question, i can set the car up to track perfectly straight and to have equal links etc, but my endpoints are different left to right for full throw, so something is amiss.. that is what got me looking back into the build and questioning why the manual calls for an off centre horn.
You didn't make a simple mistake like use the wrong Ackermann plate on one side or something, did you? Ballstud spacers are the same, VLA is correct?
#703
#705
This company makes a nice fan mount that works perfect on the stand up tranny:
RC Speed Secrets - Performance Level Parts & Hop-Ups | RC Racing Parts
http://rcspeedsecrets.com/rcss-losi-...tor-fan-mount/
It goes on the screw that goes through the tranny to the motor plate, the 44mm one, works out really nice, they have some other nice products as well.
