Tekno RC EB410 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree2421Likes
Last edit by:
Print Wikipost
Old 10-13-2017 | 02:50 PM
  #1561
Originally Posted by AntH3000
Under acceleration on carpet this distribution is great, but on corner entry and mid corner I'm not convinced based upon the tyre width offset front / rear. Nice to see those figures on vertical wheel forces under acceleration.
Simple math, no worries.
I watched the Jason Snyder video and agree with you, the car over uses the front tires simply because there's more load on them. To be fair nothing seemed bad, the opposite actually. The car stays on it's nose and the rear rotates willingly and locks in when on power, it's natural to most drivers. Still 52:48 might change in the future to become 50:50 once the team starts to figure it out.
30Tooth is offline
Old 10-13-2017 | 02:51 PM
  #1562
Originally Posted by Cain
you know at some point, maybe companies should just not include the plastic horns and include what appears to be the industry standard 25T.
Spoke with Amain, they are looking to find out the part # on the horn.
Probably because most servos include an aluminum horn in the box that they ship with. I am using the horn that came with my protek servo. So why would manufactures include it when the servo companies already do.
BaggedRanger is offline
Old 10-13-2017 | 02:56 PM
  #1563
I am talking about the protek part # for the horn someone mentioned could be used. So not this: TKR6563A
Nowever if that Ruddog horn works I have 2 of them here to try out when time comes. Cheap too, heck was $8.99 at one point.
Mine was the horn that came with the servo..
https://www.protekrc.com/2014/12/18/...al-gear-servo/
Old 10-13-2017 | 03:32 PM
  #1564
jmcelroy42's Avatar
ProTek is the only one that I know of that does that, and only on the higher end servos.
Cain likes this.
jmcelroy42 is offline
Old 10-13-2017 | 03:33 PM
  #1565
suzukipro's Avatar
Originally Posted by Tbuggy
Yup it worked for me as well.
Luck for me I have a couple of those Protek horns
suzukipro is offline
Old 10-13-2017 | 04:27 PM
  #1566
awesome build
ready to go..
snowninja is offline
Old 10-13-2017 | 07:19 PM
  #1567
rvrslt1's Avatar
Originally Posted by snowninja
awesome build
ready to go..
Looks sweet!
rvrslt1 is offline
Old 10-13-2017 | 07:35 PM
  #1568
SCRAFAN's Avatar
So has anyone run this yet on med to high bight clay? Thoughts?
SCRAFAN is offline
Old 10-13-2017 | 08:38 PM
  #1569
i did the same! lol was like WTF then realized what happened.
Add me to this group!
DG Designs is offline
Old 10-13-2017 | 10:00 PM
  #1570
Originally Posted by E-Mann
A few build notes:
And for anyone who is curious neither xb4 or b64 center slipper will work on this kit. The xb4 is close and I think with some tweaking could fit. It's about 2mm too long in Stock form.
So then...
rvrslt1 and Tbuggy like this.
Old 10-14-2017 | 07:06 AM
  #1571
Two extra holes drilled on top of stock mount...voila. <br/>Maybe Tekno should just do that from the start!?!
Now I can run the 81t with a 30 pinion!
Tbuggy is offline
Old 10-14-2017 | 07:39 AM
  #1572
jasburrito's Avatar
Does that clear the body? Is that a kinda chowed pinnion against that new spur gear? Sweet ride.
Tbuggy likes this.
jasburrito is offline
Old 10-14-2017 | 08:00 AM
  #1573
Honestly haven't done a body fit yet. But its almost in the same position for the most part as it would be if mounted with the CF top plate. So I don't see why it wouldn't fit.
Ha ha, that is an old pinion. I have a new one in route, I was just trying to get the spacing down atm. Good eye!!
Not running this until it is 100% complete. I still have to build the shocks and add the cf parts I am waiting for.
Tbuggy is offline
Old 10-14-2017 | 08:33 AM
  #1574
Cain's Avatar
Tech Legend
anyone get a notice from tower? status went from Mid Oct to on order. Mainly curious if your orders drop to processing.
Cain is offline
Old 10-14-2017 | 08:40 AM
  #1575
Originally Posted by DG Designs
So then...
If it's 21mm between the inside of where the bearings sit it could work. That is what I measured on the tekno center diff.
E-Mann is offline
