Tekno RC EB410 Thread >
Like Tree2337Likes
    Hide Wikipost
Old 01-17-2019, 05:13 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB410 Thread
Last edit by: tobamiester
Welcome to the EB410 Wiki page.
Basic Stats/Features:
  • Shaft drive (tapered AL for light weight and straightness)
  • Gear differentials (all 3)
  • Low Angle CVAs (with captured pins so no ejecting them!)
  • Durable stub axles with 12mm hexes and optional offset adjustments
  • Reverse bellcrank steering system
  • Quick access bulkheads (for easy diff maintenance and tuning)
  • Spllt center diff holder (for easy diff maintenance and tuning)
  • 8th scale style motor mount (for easy mesh adjustment)
  • 13mm big bore shocks
  • 3.5mm shock shafts
  • Droop screws
Videos
Servo Horns
Tekno included a plastic servo horn but also offers an aluminum one. This is highly recommended. Here's a list of servo horns that have been found to work:
Gearing:
Works out of the box for mod or 13.5.
  • Preference for Associated factory team pinions
  • Start mod gearing around 21t pinion
  • Start 13.5 gearing around 29t pinion with the stock spur (81tooth). If using a Tekin Spec R 13.5, start with a 24t pinion for medium sized indoor tracks.
  • Internal Gear Ratio: 2.5:1
  • For comparison:
  • B64 is 2.47:1
  • 22-4 is 2.4:1
  • YZ4 is 2.6:1
Wheels
  • B6/22/rb6 wheels direct fit
  • 22-4/XB4 front wheels direct fit
  • B64 front wheels will fit, but you need the +1 hexes (can use #TKR1654X, which is a +1mm hex)
  • 22 2wd front wheels will also fit, possibly a good option for carpet.
Setup Sheets and other documentation
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
Aftermarket Upgrades:
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Build Tips:
  • When fastening the steering posts with a 5.5mm socket wrench, you can back space the socket with some nuts to help drive the post into the bulk head
  • Place an alcohol swab over metal threads and drive screws through the swab to clean both sides of threads before applying thread lock
  • Use a metallic marker to indicate what fluids you have filled in your diffs for easy identification
  • Apply thin layer of grease on crown gears to help hold gaskets in place for easy hole alignment
  • Bags F and H have 2 different size set screws, be sure to use the smaller 3x3mm screws for the hexes or you may run into problems installing wheels over the hex if you use the longer 3x4mm screws
  • To make is easier to slip the o-rings on the shock cap bleeder screws, apply a drop of shock oil and slip them over a 1.5mm hex bit, then line up the bit with the screw and transfer the o-ring over using fingernails or needle nose pliers
  • pinch+rotate shock caps in 17mm hex wrench to improve roundness
    More shock build tips here
  • Use a 3.05mm drill bit or 3.05mm Kyosho arm reamer, 1/8" drill bits are not recommended because they are 3.17mm in diameter and tend to introduce too much slop, the pins are roughly 2.97mm in diameter
  • Replace the stock 3x14mm screws (TKR1405) with 3x20mm screws (TKR1409) in step H-10 in the manual in order to increase durability to the bulkhead.
  • When installing the front and rear differentials into the bulkheads be careful when tightening the 3x8mm screws of the cover that holds the diff in place. Bottom out the screws first (use a hand driver and make it hand tight) then check the diff to make sure it rotates smooth. If it binds up, start by backing out each screw 1/8-1/4 of a turn until the both front and rear diffs move freely. The plastic threads will keep the screws in place so don't worry if you think the screws are not secure.
  • When installing the steering hub kingpins (TKR6596), drive each one in hand tight only. Then check the movement of the steering hub. If it binds up, back out the kingpin screws by 1/8-1/4 of a turn until it moves freely. Then install the set screws (TKR1601) to hold it in place. Only drive the set screw in until you make contact with the kingpin. Do not force it.
  • If using the low profile servo mount, be sure to use smaller OD (outter diameter) washers to avoid rubbing on the center drive shaft. Protek ball stud washers are a good example of the acceptable diameter. You can chose to not run washers though it is recommended to use them as it makes for a more secure mount.
  • Ball Cup Alternative from AE: ASC91453. These are used as a harder composite option if you are not happy with the softer stock plastics. Note that these are approximately 2-3mm shorter and require compensation when building your kit to the manual specs to achieve proper camber/toe settings
  • Wheel Nut Alternative: Yokomo 4mm Thin Aluminum Serrated Flanged Nut
    https://www.amainhobbies.com/yokomo-...-n4flt/p541494
  • Moving Rear Shocks to the Front of the A-arm
    This is the break down of what's required by one of the Eb410 FB users.
    Joey A.
    So since there has been some people wondering about running the shocks in the front of the arm I though I would try explaining everything that I did to get them to work and why. My goal was to run as much stock stuff as possible with the least amount of modifications.
    -Arms- need to be flipped and 1mm shaved off the back (spacing the arm farther back) running it this way the car is still a mm shorter then stock but more material could be removed for more adjustability but I have found no need to make the car longer.
    -Inner ball stud- there are 2 ways of mounting, the first can be used with the stock plastic tower. All you need to do is use a 10mm ball stud instead of the lower shock mount screw and a little clearance from the shock tower and diff case. Using this method will work but the ball stud is moved lower and farther in then the stock locations which requires different pivot locations to try and correct roll centers. The other way (preferred) using the option carbon tower drill a hole higher and farther out if done properly you will be able to get the ball stud location in the correct hight(0mm) and between the two stock locations.
    -Shocks- only 2 changes from stock you will need to space the top shock mount 2mm out. You will also need to run around 1.5-2mm less droop depending on your setup.
    -Sway bar- this is the hardest part of the swap. This can be done a million ways I chose to print a mount in the stock ball stud location which allowed me to use the stock swaybars and arm mounting position. You can also bend your own bar and use the stock mounts on the back. You will have to drill your arms on the other side and closer to the pivot for this to work (remember you will need a thinner bar the closer you mount the lower pickup on the arm to get the same feeling as stock).
    -Other- you will need to remove the drop screws on the rear arm. Depending on rear rims,hubs,ballcups and setup you might need to clearance the outer ball cup so it doesnít rub on the wheel.
    -Why- the benefits of running the shocks in the front are the ability to run a softer rear shock package without giving up corner speed and pack. The car will land without chassis slapping or packing out as easy allowing you to drive the car harder and it corners flatter and rotates faster without losing rear grip.
    Sorry for the shity grammar,
    TJR
    Sway bar mount for forward mounted shocks: https://www.ebay.com/itm/Tekno-EB410...4AAOSwYNxahFkq
Print Wikipost
Old 10-14-2017, 10:40 AM
  #1576
EbbTide's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Cain View Post
anyone get a notice from tower? status went from Mid Oct to on order. Mainly curious if your orders drop to processing.
No notice from tower and no update on the backorder I have on my account. Only difference is it says "on order" as you stated. I guess this gives me time to wait for the optional spurs lol
EbbTide is offline
Old 10-14-2017, 11:00 AM
  #1577
Tech Legend
Cain's Avatar
Trader Rating: 255 (100%+)
yeah, tempted from amain but even without tower e-cash 5% more savings is 5%. So will see.
rcnut87 likes this.
Cain is offline
Old 10-14-2017, 12:57 PM
  #1578
Trader Rating: 36 (100%+)
Yomomo’s 20mm clamping alum horn fits perfect with the low pro servo.
Just a heads up for those whom don’t know about Amain’s 10% off any size order, thus code is SUMCAT10.
Norse is offline
Old 10-14-2017, 01:11 PM
  #1579
Check out the video of a fella taking his EB410 on it’s first run. The 410 Looks really really good and the track is far from being med to high bite as it’s the opposite hence old school fairly large outdoor dirt track, thus it’s super dry, dusty, surface is shaling and it’s bumpy with some fairly big jumps as well. It’s on the EB410 Facebook page.
Norse is offline
Old 10-14-2017, 01:21 PM
  #1580
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
It looked pretty nice!
Norse likes this.
sickpuppy1 is offline
Old 10-14-2017, 01:22 PM
  #1581
Doug2507's Avatar
Started building my kit. Noticed on the rear left hub the stub axle has approx 0.5mm play in it. Other side is nice and tight. Washer between bearing and hex is fitted. Anyone else got this?
Doug2507 is offline
Old 10-14-2017, 02:07 PM
  #1582
Maiden voyage, new platform thus on the opposite end of med to high bite being dry, super dusty, low bite bumpy old school dirt track is really impressive. Combined with the large jumps this wheeler has the DNA.
Norse is offline
Old 10-14-2017, 05:16 PM
  #1583
anybody know if tower hobbies got the kits in yet my back order page changed from mid october to on order ?
mrlosi1 is offline
Old 10-14-2017, 05:34 PM
  #1584
wrightcs77's Avatar
Trader Rating: 540 (100%+)
Read they got them in and are shipping Monday
wrightcs77 is offline
Old 10-14-2017, 05:57 PM
  #1585
Tech Legend
Cain's Avatar
Was it this vid:
+ YouTube Video
Norse likes this.
Cain is offline
Old 10-14-2017, 07:20 PM
  #1586
anthonyjesmond's Avatar
Trader Rating: 94 (100%+)
FYI the exotek slipper eliminator for the B64 fits perfectly for those who run 13.5 on carpet
anthonyjesmond is offline
Old 10-14-2017, 07:44 PM
  #1587
Was it this vid:
+ YouTube Video
Knowing what I do about Chinese tracks it would be un-prepped and rutted from 1/8th buggies so thats not a bad run.
I think that young fella may be a team driver as well.
renjie is offline
Old 10-14-2017, 08:38 PM
  #1588
Was it this vid:
+ YouTube Video
Thatís it Cain
Norse is offline
Old 10-14-2017, 11:08 PM
  #1589
With the latest speed controllers (EG Hobbywing) having various ways of tuning torque rise rate, why bother with a slipper at all even in mod?
AntH3000 is offline
Old 10-15-2017, 05:20 AM
  #1590
Default Broken front bulkhead
Got it all assembled and a few jumps in my EB410 hit a nose dive landing and snapped the front bulkhead
Attached Thumbnails Tekno RC EB410 Thread-22551722_10215058335158074_1976011839_n.jpg   Tekno RC EB410 Thread-22497468_10215058334918068_1207097416_n.jpg
charvel74 is offline
