XX-4 Forum
#1406
Briguy:
Are your Trinity 3800's and SMC 3200's sadle packs? If so, do you have part #'s for them please.
#1408
Briguy:
Ok, thanks....
Can someone that is using Roar approved Lipo saddle packs in their XX-4's let me know the brand name and mah of the ones they are using. I would rather not remove material from the center belt cover to use my SMC 4900's.
thanks....
Ok, thanks....
thanks....
#1409
Even 4900 saddle packs will have the same problem . If you don`t want to do any modification to the chassis you will need lower mah lipos . This buggy was designed for Nicads and Nimh batteries . You might be able to fit soft case lipos with a high mah . Measure the buggy and look online at the specs .
