XX-4 Forum
#1248
That is one nice looking XX4
Is that a XX-4 WE shock tower, than xx4 shock tower and then xfactory shock tower?
#1249
R/C Tech Elite Member
#1250
maybe if the carbon fibre braces were thicker that would be all you need with 1x std shocktower..as the ones in the pic look very thin..I just got some of the xfactory carbon braces and they are way thicker.
#1251
#1252
Here's mine, these are the braces from fibre-lyte in the uk but they are very similar to the xfactory ones, i've never broken a rear tower and have only cracked the molded front tower which means you can still finish your race, i doubt you will ever break both the molded and carbon one when bolted together, those penguin braces are so thin you can snap them with your fingers.
Peter
Peter
#1253
Does anyone know if XFactory are sold in stores? Looking at around $27 - $32 for international freight from XFactory. Can get a whole buggy sent for the same price Might try and see if I can purchase those fibre-lyte ones
#1254
Mate try DMS racing in the uk they sell them under the E speed name and they only charge a few pounds to send small stuff to Australia.
Peter
Peter
#1255
What would be a better servo to use for steering? Hitec HS-5645MG, Hitec HS-5645MG or HS-925MG? I only have a choice of those 3 at the moment as I am after one in a hurry. I was using a Air 94358Z in my XXX-4 but that servo was mainly bought for the REVO
#1256
I got one forsale. Its the non worlds chassis but its in good shape. $125. I know a lot of u lipo guys prefer this chassis, I was goin to turn it into a X5 but its discontinued. LMK
#1257
that is ghetto as with two shock towers. if you flip over that much you should get one of those tyco cars from kb toys that you can drive up side down or right side up. i am going to go get my shotgun now
#1258
And then what are you doing with the shotgun?
Last edited by Marcos.J; 08-17-2009 at 11:41 AM. Reason: removed profanity from quote
#1259
Before you shoot your mouth off any more you might be interested to know that this is a common mod for guys running on rough tracks and/or with big jumps as running on the outer upper shock holes often leads to blown up shock towers on hard landings. Another reason for bracing is that the front tower's camber link holes are prone to cracking and running a brace helps keep this from happening as often. Lastly another good reason is when you run on a track with anything big and heavy that might land on you hit you head on going the wrong way. This mod is not just a solution for people who flip alot.
#1260
Thanks, ill check them out
Peter
