Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 10-19-2016, 03:25 AM
  #3871
sport10's Avatar
Originally Posted by Balony
Using the short eyelet on the front keeps the droop the same as a long eyelet on the rear due to the front is raised due to the anti squat that is built in to the rear mount.
Thanks, makes since now.
sport10 is offline
Old 10-19-2016, 04:26 AM
  #3872
Originally Posted by TonyCooperUK
I have a B5m thats fully tricked up, not really worth anything here in UK, I know that the schelle rear hubs will fit but I lose axle height adjustment
also looking at it I have ally rear wing mounts, but they would move the wing 10mm forwards,
is this likely to be an issue?
just trying to save parts from waste on the B5m and upgrade the B6 without spending a fortune again LOL
I'm pretty sure I read on Schelle's website that their rear hubs for b5 and B6d are the same part #. B6 however has a different hub part # from Schelle.
RookieRacer00 is offline
Old 10-19-2016, 07:46 AM
  #3873
Trader Rating: 49 (100%+)
anyone see the photo of Rivkin's B6 on JConcepts Facebook Page?
That front tower is thick as hell
Scott R is offline
Old 10-19-2016, 08:48 AM
  #3874
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
it looks normal to me.....
Wildcat1971 is offline
Old 10-19-2016, 09:05 AM
  #3875
Not to me
Scott R is offline
Old 10-19-2016, 09:15 AM
  #3876
Not to me
Looks like my stock one.
Tijuana_Taxi is offline
Old 10-19-2016, 10:39 AM
  #3877
+1 for stock
Uhudler is offline
Old 10-19-2016, 11:06 AM
  #3878
SMcD's Avatar
Trader Rating: 61 (100%+)
sport10 and Balony, thanks!
I ran some practice laps yesterday. Basically, after practicing, I switched to the short eyelet. The dogbone pin is just so close to the end of the outdrive at full droop that in the right crash event, the bone may pop out causing DNF. I also suspect that the piston is better placed in the shock fluid column with the short eyelet at the front of the arm.
I am not super fast, but I love the way the car handles in this configuration. Just gobs and gobs of steering, carries so much corner speed, jumps flat
SMcD is offline
Old 10-19-2016, 11:25 AM
  #3879
Silverstonev8's Avatar
Are you running the cva shims 91605?
Silverstonev8 is offline
Old 10-19-2016, 03:09 PM
  #3880
SMcD's Avatar
No, but I can see how they may also help keep the bone in the outdrive. In the end, I followed Kody's recommendation and overall droop is reduced enough to keep things in check
EDIT: actually, I'm not sure this is true. the back end of my car is apart right now. I will take a real close look at things when I get it back together. thinking about it now without the car in front of me, I think the biggest effect is the tension on the shock spring as the eyelet "looses" length at the shaft/spring retainer (threads are showing now) and not the bottom. this will mean I have to change the shock collar setting to maintain ride height. uuuggghhh confusion...
SMcD is offline
Old 10-19-2016, 04:38 PM
  #3881
tony montana's Avatar
Trader Rating: 76 (100%+)
Sean you running laydown?
tony montana is offline
Old 10-19-2016, 07:58 PM
  #3882
SMcD's Avatar
Yeah. After looking at Hunter`s buggy, I went all in.
SMcD is offline
Old 10-19-2016, 08:12 PM
  #3883
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
http://www.redrc.net/2016/10/rdrp-b6...hinge-pin-set/
RCBuddha is offline
Old 10-19-2016, 11:38 PM
  #3884
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Which car does most people use for both Mod and Stock? I am contemplating on getting a buggy to play with for the winter.
ChadB. is offline
Old 10-20-2016, 04:27 AM
  #3885
Do the new style ballcups need to be squeezed like the old ones and are the new ones compatible with the 5 platform?
