Team Associated B6 & B6D thread
#4021
Just built the 4 gear stand up. Does it matter what side the ball diff hex bolt head faces?
In the manual for the standard 3 gear it mentions to have the ball diff hex bolt head same side as spur gear. In the sc5m manual which has the 4 gear it mentions the opposite. Ie ball hex bolt head opposite side to spur gear.
Mark
Mark
#4022
here we go
#4024
Any thoughts on set-up for a medium sized clay track with low-medium grip that has long straights, multiple 180s and big jumps. Not very technical. Running stock with 69/31 gearing and laydown transmission with rear shocks to the front of the tower.
After reading about suspension geometry, I was thinking of moving the top shock position to the outer positions and going 30 degrees on the kickup.
I've already changed to shock oil to 32.5 front/30 rear. Gray springs front/ Green Yokomo rear. What do you think?
Should I add back my waterfall brace?
Thanks guys!
Thanks guys!
#4025
Thanks guys!
Thanks guys!
#4026
What is the downside to running the b5m kashima rear shock without a longer shock tower? Is buying the longer tower a must or can I do something with upstop/downstop shims.? Thx couldnt find he rationale
#4027
Pop Survey: I'm still debating about picking up a B6/D somewhere around the New Year. I am curious about actual numbers and not about "this other guy at the track". So if you have had to personally replace the items below due to breakage, let me know how many times.
How many have you replaced:
Front Tower:
Rear Tower:
Chassis:
Front Tower:
Rear Tower:
Chassis:
#4028
#4029
Front Tower:
Rear Tower:
Chassis:
Front Tower:
Rear Tower:
Chassis:
#4030
I.e. technical track with small jumps VS open layout with big jumps
#4031
So I've managed to break 2 front shock towers so far, with about 20 packs through the car at our local carpet track. (drprc.com)
I've seen pics on B6 nation of broken shock towers as well as others at the tracks. They seem to break at the hole closest to the center of the shock tower. This makes sense as its the obvious stress riser. The failures on mine where the result of an impact to the front of the vehicle, and not from a load in which the tower was/is designed to carry.
That said, if you're not using the upper/outer most shock mounting hole, consider deleting that part of the tower via sanding/grinding/dremmeling it off. This reduces the "lever" acting on the area of tower's arm that's prone to breaking.
There will be those that may not agree with this line of thinking and that's fine. But it's either this or fabricate an aluminum tower for me.
I lack the post count to add pictures. So here is the link.
https://www.facebook.com/groups/1464...2369150323808/
#4032
We race outdoors on a rough hard track and I haven't broken anything on my B6 or B6D yet. However, I let a friend run my B6D on its second race day and he turned it over and supposedly broke a rear tower....it was returned to me fixed. I think the towers are the only weak point. When AE was at our track testing tires their team manager said that its only the towers that get cut from the ends of the CF sheets that seem to be more brittle and AE is addressing it. Honestly, I liked the plastic towers on the B5M better. I'm still not 100% comfortable with the B6 & B6D but neither of them has slowed me down. I don't know the cars that well yet and have a harder time making adjustments. I knew exactly what to do on the B5M but not so much on the new cars.
#4033
Front Tower:
Rear Tower:
Chassis:
Front Tower:
Rear Tower:
Chassis:
Front Tower: 2
Rear Tower: 1
Chassis: 1 (don't ask)
Plastic front bulkhead: 2
Regards,
Doug
#4034
Thanks Guys. I think we can stop now before Matt has steam coming out of his ears.
#4035
