RC10T4.1 Thread.
#2536
I haven't run it on the truck yet but I have the Garo disk on the back with a vented plate and then the VTS on the front on my Mod Buggy and I love it. The same set-up is going on my truck that will hopefully be finished by Christmas.
Blake
Blake
#2537
Hmmm, if I wanted to go garo, I think I would use the stock gears and the hex pads or get the vts and maybe the garo vts pads. The only reason I got the triad was to hopefully have my pads last a lot longer. If that proves to be false, I will sell the triad and get a pair of garos and just run the stock spurs.
#2538
#2539
With the two people above that just posted our options keep growing. Not to mentions the advice that comes from them being spot on. I eventually want to try a Triad but right now I want the two to be identical more because I know what the VTS does and what I want as far as setting.
Blake
Blake
#2540
The Triad pads last really well, I typically change them every 2 months of racing weekly. Two things: 1) the pads have a small change after break in, so we advise re-checking the slipper after a couple runs to tighten it a bit. Also wipe off any white dust from break-in. 2) The clutch has more power capacity, so it can still drive your car even when it's too loose, but this will make excess heat. Please take the time to confirm it's set right before running a bunch of packs.
#2546
does anyone run 12mm hex on the t4.1?? if so what brand
#2547
new here just wanna know if anybody runs 12mm hex on there t4.1
#2549
