RC10T4.1 Thread.
#2386
#2387
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
What foam our most of you guys running for stadium truck?
#2388
#2391
you can see the axles...and some cleavage in this video. The axle are shown at 2:49
http://www.youtube.com/watch?v=5nS7K1HqmzQ
#2393
Ok don't feel like reading through tons of pages so hopefully you guys don't mind answering a few questions. What gearing would you recommend for a reedy 17.5 on a high bite motorcross large clay track. As well as those running the big bores what springs are you running (avid or AE). Thanks
#2394
#2395
the sc10 hex has a higher offset (thicker) than the b4 hex (thinner), so the wheels will get pushed out farther. i have both sets of hexs and have checked. so unless they did something really fancy with the bearings and steering block, the sc10 hexes with the JC axles will make the t4 wider
#2396
At WCRC the most common setup recommended is 75/29. I run that gearing with some timing on motor and it comes off the track around 135* after about 10 min. Give it a try prim.
#2397
#2399
#2400
The Jconcepts axle is machined and has a shoulder where the "C" clip would normally go. So you dont have to worry about over tightening and binding the front end up. Its a little longer than the AE's so that you can use a SC10 rear hex. Not sure exactly how much wider the front would be with the Jcon axle and SC10 hexes over the AE with the B4 rear hex but my guess would be 3-4mm.
