RC10T4.1 Thread.
#1036
Man that's weird. I had a older t4 I had since 2005 and never had to replace any gears. I ran mm7700 and 8.5t tekins no issues. Metal gear isn't going g to actually fix the issue. The only thing I can think of is that you are tighting your transmission case so tight that the binding is causing the older to lock up and fail. Your transmission your roll butter smooth. Just an idea.
#1037
ive never messed ith the ball diff since i got this thing (used) a few months ago but i cant see how that could be causing any issues since it iw working find and dandy,,, It is probably due for a re build soon so i will tear into it in the next few weeks when i get some scratch for some new balls and rings etc,,,
#1038
Tech Legend
Hey guys,
My T4 FT seems to keep blowing out the idler gear, even with my slipper loose, It first started with a bearing that blew out and got dissinegrated inside the trans, somehow it only munched the idler and i was able to get it backtogether with a new idler replacement and a new bearing,, it lasted about a week (id roughly say 10-12 packs run through it) and then started clicking again, i tore it down and found the idler chewed again so this time i replaced all the parts i could buy locally
1. Trans Case
2. Topshaft & Gear
3. Another new idler (white plastic)
Thats seemed to be pretty good, i thought my trans issues were over and done with now i been running it about a month but alot less running so i would still say i only ran about 10-12 packs through it. I keep my slipper very loose and when i take off (on concrete) i can hear that slipper slipping for the first 10-20-30 ft so im wondering why i keep ripping the idler gear.
it started ticking again on my last run so i know it wont be long till im replacing it again.
Im looking at possibly getting the Hot racing or Robinson racing steel idler gear from the SC10 for it and then see what the outcome is. Now im wondering though will this gear fit right? i read something about there beint two different trans cases and some different sized bearings or something???
Any info would be much appreciated.
Any ideas or suggestions??
1. Trans Case
2. Topshaft & Gear
- Did you replace all the gears in the transmission including the differential gear? Reason I ask this is that maybe there is something wrong with the gear causing excessive wear.
- Are you sure you are letting your slipper slip 10 - 20 - 30 feet? That sounds VERY excessive.
Please post pics of the gears in question.
#1039
Very basic questions related to the idler gear as well:
What motor/batt/surface? I've seen idler gears go on T4's only when someone's trying to run a 6.5 on carpet or whatnot.
You are letting off the throttle when your truck gets airborne at all, right?
Are the bearings in the idler gear still totally free and in good shape?
#1040
First thoughts:
#1041
Yes & trans is smooth as butter when complete and bearings new in good condition
This is my whoe reason for posting i dont get it im not doing anything that should be excessive on the gears, no 3s no full throttle jumps no grass to concrete type burnouts etc,,,
#1042
anybody try the x60 conversion yet?
how did u like it?
how did u like it?
#1043
SV2 & Tekin Redline 7.5T running 2s anywhere and everywhere mainly grass or loose dirt
#1044
http://www.valvoline.com/products/co...-oil/grease/64
enough in that can for about 1 billon tranny, doesnt take very much at all. which you only use it on the gears, be careful not to get any in the diff.
i only decided to try it since i had some from doing a bearing job on my full scale, seemed alot smoother and made less noise then any "shock oil, or diff oil", also motor temps went down 3-5 degrees, which isnt much, but better then the other way
#1045
Hey guys. This is the best RC ever made. I originally have a rc10t4 factory team back in 2005. Solid truck never had any issues. I sold it for school back in Oct 2011. Only RC i regret selling. So thanks to towerhobbies easy pay I picked up a brand new rc10t4.1 ft, Robinson racing hardened aluminium different gear for the gt2(ran it on my older t4 early had to rebuild my diffs and can easily hands any brushless) brand new Tekin Rs Pro 7.5t combo, got some Gen ace lipos and a new spektrum dx3c(my first.2.4). Ill be running it at bashers RC raceway in palm beach garden Florida. I wish she has full carbon BC its a factory team but I'm amazed the improvement made to the quality and some parts design.
#1046
#1048
#1050
I'm still lost as in how grease is lowering g your temps if it does cause some drag. And as for his idler issues...I figured it be the case being tighten down too much.
