RC10T4.1 Thread.
#1051
You know what. That's exactly what it is. The slipper is heating up so much that the top shaft transfers that heat to the idler. I had the same issue on a rustler when running a 7700 before the metal gear were available for the truck.
#1052
Newbie Question on RTR Gear Diff
Hi, I have a question on how to tune a gear diff. It seems like only one wheel on my truck will hook up. I had it at an outdoor very loose track and on the straight the truck would go sideways to the right and the rear end would spin out on most turns. Should I go heavy diff oil or pack with grease? Any help would be appreciated.
#1053
#1055
Odd, they shouldn't feel the same.
#1056
I have a pile of spare parts if anyone is interested.
#1057
Super Moderator
Trader Rating: 31 (100%+)
Matt, and everyone, posting about stuff your selling isn't allowed. Especially links.
#1058
Well I got to test out the T4.1 FT.
I gotta say it is fun..
I ended up using a 1410 3800 motor. I hate it.
Used it for 2 days... IT came out last night. lol
truck seems to handle well with the stock springs, ended up installing a gear diff with 5k oil.
I got a set of the Avid front truck springs. ---Yes Jeff S. I got them at the hobby shop... there ran out of rear truck springs and going to be installing a 10.5 .. the truck class here is all a mod class. no spec motor as of yet
#1060
Kevin
#1061
Someone asked what i used for lube in the trans, ive tried it dry and it wore the gear quicker but then again that is also when i finally saw that the one bearing was shot, this last time i just used a dab of Associated black grease on the top shaft gear which after time spread to the other gears as well im sure but i used very very little, next time i go through the trans i'll use NONE like is reccomended.
#1062
Hey guys what pinions should I keep handy for my truck? I just got the truck and it came with no pinions. What should I be looking for in pinion size running a 9.5 turn brushless motor on small to medium technical tracks?
#1063
I changed the front bumper on my T4.1 Brushless to an RPM after breaking an A-Arm. Before I could even mount it, 2 of the 4 screws were stripped. Has anyone else stripped these? Is there a fix, other than replacing the piece?
