SC10 4x4 Thread
#9961
Just ordered my basket and garolite pads. Oh, and the truck will be here friday.
I have been following this thread since day one, so i have a good idea how to make this bastard child faast. WooHoo
Oh, and are the trackstar orings still worth it, or is running the lower stock x ring just as good
I have been following this thread since day one, so i have a good idea how to make this bastard child faast. WooHooOh, and are the trackstar orings still worth it, or is running the lower stock x ring just as good
#9962
thats exactly what i am thinking too. i do have some ackerman bars in the works though!! will test after the RCpro finals this weekend. practice start tomorrow!
Need me to test some of the parts wink wink
Hey can anyone PM me all the part numbers for the saddle pack conversion so I can give it a try?
Here.http://rcshox.com/shoxshop/catalog/p...0f3b9bb0b5b4ab
?Hey can anyone PM me all the part numbers for the saddle pack conversion so I can give it a try?
#9966
#9968
in the sway bar kit ther is 3 different onec i think one off them is the 1,8mm.
http://www.amainhobbies.com/product_...ar-Swaybar-Set
but im not 100% sure but pretty sure its 1,8 2,0 2,2 mm. ther is in the kit but its just a ques i get the kit in 2 days then i can tjek for ure if u need me to
#9969
#9970
RE: Batteries
I'm moving from a 7.5 to a 4.5 550 can. While my gensace 40c 5000 packs have worked great so far, it sounds like quite a few have smoked them going to the 550 can. I've seen references to the Hobbyking Turnigy nano-tech batteries. Is this the safer route? Anyone with good/bad experiences with these on a 550 (saw a couple good, but would like to hear more)? Any of those ROAR approved at all in case it comes up?
#9971
RE: Batteries
#9972
RE: Batteries
#9973
I had alot of leakage problems when i ran just a single stock o ring on lower cap position. I had used lots of green slime an still leaked . I tried the rcb8 o rings like someone mentioned on here and those were even worse , leaked and sucked air into shock. Finally tore down shocks , polished shafts, clearanced out the bottom caps as they were tight and caused a bit of friction, ran upper and lower x seals ( which are way overpriced as i was at the track and needed something to replace the rcb8 seals ) and they are pretty smooth now.
#9974
I dropped the stock bladders and went emulsion. Just like so many shocks if you have too much oil in them they will leak due to over pressure. I love the emulsion style shocks for this reason. I had no leaks on the first race day and frankly don't expect them either. I am using both stock x-rings with green slime.
#9975
5Likes
