SC10 4x4 Thread
you might want to check that closer because the sc10 2wd with the 12mm hex and the standard sc10 4x4 wheel it is the same track width as the sc10 4x4 with hazard wheels and with hazard wheels on the sc10 2wd it is 6mm wider then the sc10 4x4 we have a sc10 2wd
so if the sc10 4x4 is at max track width using the hazard wheels you are over on the sc10 2wd
however i run 2wd kyosho scr i thought about using the hazard wheels on it they might work pretty good on it and be within limits for track width just my observation and measurements.
JConcepts posted on their thread that the White Hazard is in the works for later this year. I wish I would have read that before ordering 4 sets of black. I also prefer the white wheels. Black is too black-on-black-on-black.
But I have to say I love the wider stance of the Hazards of both my SC10s.
Then imma wait till white Hazards are released, I think the stock ones can still last a month
All I do is train and train and train more... I'm not in a hurry for newer tires.
Originally Posted by Vegatron75
I was able to get through mine w/ a hand drill and a vise. I must have got and relatively soft one. I did drill a pilot hole. The aluminun part is soft, if it won't go through the shaft pretty easily, then stop and take it somewhere. It ain't got to be pretty, it's hidden..... Just remember to loosen your slipper way up, i you don't your idler gear will most likely be toasted.
At least I would.
It ain't got to be pretty, it's hidden..... Just remember to loosen your slipper way up, if you don't your idler gear will most likely be toasted.
Who said anything about the motor? or metal shavings? What the heck are you talking about?
Even it it doesn't stick and the motor is sealed enough to keep the shavings out, it just doesn't seem wise to me to have them getting anywhere near the truck.
I just got a message from Manits, and he said he went to a toe in of 1 deg, then won the qualifier! He said "thanx!" for the suggestions. Last night we added more punch to his esc and tuned down the breaks, which also helped.
I know he has not made the new ackerman bar yet, but will get on it soon. I think this truck has too much ackerman built into the bar. which cannot be adjusted. That is the reason we all run our teering around 80% d/r. I for one cant wait to try a new ackerman tht will make the truck less edgy.
I do not have a SC10 4x4 but I might be able to use the CVA's from it if I knew the lengths of them. I'm looking for a CVA that is 100mm, does anyone know the length of the SC10 4x4 CVA's (front and rear)? Thanks in advance.
Hey guys,
Sorry if this has been asked as I have been reading this topic, but it's hard to read over 10,000 posts. I just purchased a used SC10 4x4 in great condition. I plan on racing this weekend. It came with FT hexes and FT turnbuckles. It has a Novak 5.5 HV motor, MMP esc w/bec, DS 1015 servo, and some type of slipper upgrade. Is there anything I need to know about this specific set up? Also, is there any parts I should purchase to have ready on hand.
Hey guys,
5Likes
