Like Tree5Likes
SC10 4x4 Thread
Old 06-16-2012 | 01:27 PM
  #25111
SOuthernFRIED's Avatar
Here is the setup that fixed the push I had. I would like to thank everyone who offered suggestions to help me out. There are some great folks on here and the improvement in my truck reflects their knowledge.
I went to the blue springs in front, removed the yellows. In the back I switched the lower arm mount to the inside. I also went up on the center diff from 5 pins to 7. Truck is the best it has ever been and my lap times reflected it!
SOuthernFRIED is offline
Old 06-16-2012 | 03:07 PM
  #25112
ryanpatrickgore's Avatar
I'm working on Building my ft right now. I just found that one of my hinge pins was 4mm longer than the other. I had to cut to size with my dremmel. Anybody else come across this issue?
ryanpatrickgore is offline
Old 06-16-2012 | 03:44 PM
  #25113
Mine is apart right now and I checked. .1mm difference between the two...
jayrat is offline
Old 06-16-2012 | 03:55 PM
  #25114
Hey guys, I posted yesterday about a clicking that I thought was the rear diff. It just seems to do it for a second at a time under hard acceleration. I used 6mm of up limiters on the shocks from the build. I've only ran this truck for about 1 hour. It wasn't clicking originally. Today I pulled the rear diff apart to find everything in mint condition. No visible wear or damage. Question one--Should I shim under the sun gear with the 3mm shims that I have or should I use 5mm under each? I've read that AE is sending out 5mm shims to address any diff issues? I asked this yesterday and didn't get a reply...Question two--After I re-assemble and I believe I'll still have this issue, what else could the issue be? I've played with the slipper and the belt tension and had no luck...Thanks for any insight.
Jay.
jayrat is offline
Old 06-16-2012 | 04:01 PM
  #25115
Jake S's Avatar
sounds like you just cut down your front hinge pin...
the front IS 4mm longer then the rear.
Jake S is offline
Old 06-16-2012 | 04:45 PM
  #25116
JEFFs SC10's Avatar
7 pins for what kind of grip?
I ran 4 today on a low-med grip.
JEFFs SC10 is offline
Old 06-16-2012 | 04:47 PM
  #25117
Evil Genius jr.'s Avatar
Race report!
Broke a bellcrank in practice
Q1 came in 2nd
Motor shifted every couple of laps Q2
Q3 Radio broke
A1 Stripped spur
A2 Different motor shifted
So yeah...... not sure what else to say.
Evil Genius jr. is offline
Old 06-16-2012 | 04:49 PM
  #25118
Jake S's Avatar
Originally Posted by Evil Genius jr.
Race report!
Q1 came in 2nd
Q3 Radio broke
A1 Stripped spur
sounds like someone needs some new motor screws and some better tools if the motor keeps shifting
Jake S is offline
Old 06-16-2012 | 04:50 PM
  #25119
Oh yeah forgot my nice hex wrench stripped after all this to
Old 06-16-2012 | 05:00 PM
  #25120
ilanstylz's Avatar
Race report!
Q1 came in 2nd
Q3 Radio broke
A1 Stripped spur
How did your radio break and you were still able to run in the mains?
ilanstylz is offline
Old 06-16-2012 | 05:01 PM
  #25121
Steering wheel broke, thankfully one of the people who works at the track had an extra parts radio so I took it off of that.
Old 06-16-2012 | 06:11 PM
  #25122
CoyoteSlash's Avatar
Drove my truck again for the first time in 2 months.
Running Coyote style except for:
- I switched out the Blue-fronts with White-fronts in the rear.
- Switched out Yellows for the Blues in the front.
The truck changed alot. I feel like I lost push which was great, but It's still not Cameron's or WC's truck from the videos. But I need to go to daves is really what it's down to. And drive what I see and see if I can duplicate it. I'm driving in a shithole right now so it's really hard to compare tuning from bench night to bench night.
I have all the parts for the 8mm mod but i'm going to hold off until I have the truck back under my control before I bolt that on and start playing.
CoyoteSlash is offline
Old 06-16-2012 | 06:59 PM
  #25123
jpure009's Avatar
Yea,
I had a brand new pack of hinge pins.
2 were smaller, the other 2 were slightly bigger.
4mm sounds right
wow, hope you didn't cut them like it sounds
jpure009 is offline
Old 06-16-2012 | 07:12 PM
  #25124
CraigMBA's Avatar
Originally Posted by Cameron Kellogg
Fair enough. I can say it was not the best choice in Pasco either. But that was a bad day all around. Real good at Dave's RC Tracks. Going to get some PRCR clay track time in next week.
Interested in how the sway hooks up to the front arms on the 2w
You want mine to copy?
CraigMBA is offline
Old 06-16-2012 | 07:41 PM
  #25125
Cameron Kellogg's Avatar
Send me a picture or something in a PM
Cameron Kellogg is offline
