SC10 4x4 Thread
#9992
I love the 4000 and think its the best all around choice. Unless you are running a car that weighs over 6.5 lbs on a very large track you shouldn't need any more motor. If you are a "one motor needs to fit all tracks" guy, the 4600 can be dialed back to work anywhere, but it won't be able to match the throttle response of the 4000. I've let quite a few guys try my truck at one of the local indoor tracks that have the tekin 4600 in their trucks already and a couple of them walked into the hobbyshop and purchased the 4000 on the spot.
#9993
RE: Batteries
I'm moving from a 7.5 to a 4.5 550 can. While my gensace 40c 5000 packs have worked great so far, it sounds like quite a few have smoked them going to the 550 can. I've seen references to the Hobbyking Turnigy nano-tech batteries. Is this the safer route? Anyone with good/bad experiences with these on a 550 (saw a couple good, but would like to hear more)? Any of those ROAR approved at all in case it comes up?
I ran those exact batteries all summer with my 4.5 turn 550 tekin motor without any issues. They felt warmer than average after dumping one, but never puffed and punch felt fine. Enter the tekin 4000kv 540 4 pole motor and those same packs came off the track warmer than I was comfortable with and one swelled a touch. I have since relegated my gens ace to 2wd and picked up 4 new 5600 mah 50-100C Hard case nano-techs and they come off the track as if I was running a stock buggy: cold.
I will try to get out to the track for a test run after I get things overhauled. I'll get a few minutes into the GensAce and see how it's doing heat wise and possibly go for one of the 65/130 nano-techs they're offer now if I'm concerned with the GensAce.
#9994
#9995
Um yeah that was me. Mine drops right in like yours when the whole slipper assembly is not together like in your photo. Take another after it is assembled in the truck and let us know how centered everything is. Something is amiss just not sure what it is with my truck.
#9996
Thanks!
#9997
Here is my RX8 Setup.
Timing advance: 10 (equivalent of 3 degrees of timing on 'other brand' esc's)
Timing range: Default (approx 5k to 20k)
Throttle profile: 3
Drag brake: 0
Brake strength: 60 is the most I've ever needed. I dial it back according to the track surface so that I'm just shy of locking the tires up. 50 is a safe all around number, but gearing will also affect this.
Throttle minimum: 10
Brake minimum: 10
Reverse strength: 20 (just enough to roll backwards if I need to during practice)
This is all geared at either 15 or 16 teeth on the pinion with the 62 tooth spur for my local tracks. Temp your motor after 3 and 5 minutes and gear accordingly, but I come off between 140 and 180 depending on the track.
lmk if I missed any... lol
Throttle profile: 3
Drag brake: 0
Brake minimum: 10
#9998
I sure will I should be done with it tonight just changing diff fluids in the front and rear and front is done. Was trying to clean the old oil out what do u guys use. I tryed this one cleaner to see if it worked and also Im trying dawn and water to see if she cuts greese ( oil ) out of my way lol
#9999
Throttle profile: 3
Drag brake: 0
Brake minimum: 10
Throttle profile: 3
Drag brake: 0
Brake minimum: 10
Thanks Kiro, that's exactly what i'm looking for!
Wiring up my RX8 right now and will hook up the hotwire later tonight.
With the 4000kv Pro 4 I'm starting with 15/62 as a fellow racer runs that gearing on his SC10 same motor and temps 120° - 130° after 6 mins, only diff is he runs a MMP esc.
Wiring up my RX8 right now and will hook up the hotwire later tonight.With the 4000kv Pro 4 I'm starting with 15/62 as a fellow racer runs that gearing on his SC10 same motor and temps 120° - 130° after 6 mins, only diff is he runs a MMP esc.
This is on a somewhat large track with a big long straight. I simply like as much power as I can get! I would bet my truck is geared to go 45mph-ish
It is freaking awesome to be faster down the straight than 1/8 buggy!
Throttle profile: 3
Drag brake: 0
Brake minimum: 10
Throttle profile: 3
Drag brake: 0
Brake minimum: 10
5Likes
