SC10 4x4 Thread
#9376
I ordered a new shaft and plate to try out the pin mod since I'll probably screw it up the first time didn't want to be without a truck while I replaced the messed up part.
I'm want to use my dremel since I have the drill press stand for it, what type/size bit should I use? I'll probably use a traxxas hinge pin from the casters as I have a few bent ones that could be put to use, either that or a spare wheel nut pin (from rustler)
#9377
#9378
Nothing against the basket or pads but I would rather not have to go that route. While it may be the ticket for the fix I would rather try something else here at home. It would be a last resort option. I am looking at how the traxxas revo/slash slipper assembly is set up. I may do something like that.
#9380
I'm really curious about this new exotekracing lcg chassis coming out for our trucks. Supposedly it's going to add 5oz more weight to our truck and be stronger. What are other peoples thoughts on this? Glorified metal or beneficial to help our trucks out? Post your thoughts up!
#9381
I put a 4mm washer between the spring and nut as well as scratched up the pads and made some grind marks on the disks and now it wheelies like crazy. Full power is restored. Now I can set my slipper to barely slip and still have the power I need. I guess I will find out how long this will last. Going to put a pack through it right now.
#9383
#9384
that machine work definitely looks nice, this could also eliminate any chassis flex as well. i don't think 100 is to bad, depends on how much that extra time means to you on the track and staying ahead of the game, guess we'll see when it's released!
#9385
Finished another pack and it still slips. Its good for a couple laps then the power loss that is very noticeable. What's the easiest/fastest way to pull the tranny out. Going to take it to the in laws to do the pin mod. God this is real irritating. It almost feels like a lipo cut once it slips.
#9386
#9387
No, just the ht pads. I have the tranny out now. I have to find that post thaat shows how to do the mod. I can't remember exactly how to do it. BTW, it's a biotch taking the rear tranny apart. Nearly took the whole rear end apart for it.
#9390
Oh ya baby!!! I had my wife hold the shaft while I drilled it and wow is it so much better. Well worth the mod for anyone looking to do it. I used the stock wheel pins from the kit and a 5/16 bit. Very easy to do and definitely worth it. I only drove it around the front yard since it is dark but from what I can see/feel it's definitely an improvement. Tomorrow I will test it out on the track and post back with results. Thanks for the help and the awesome mod.
Terry
Terry
5Likes
