SC10 4x4 Thread
#9526
what swaybar will u guys recoment i start out whit front/rear??
i got the 3 different for the front and rear on my nexx sc10 i just take it out the box put in my motor combo and resiver plug in a lipo and off i whent doing laptimes that was the same as a losi scte on 2450 motor mmm whit 3S lipo we are bothe noob drivers
#9527
#9528
okay just 1 more dumpe question
#9529
2mil shim on the outer steering knuckle wher do u mean ?? ive see somebody put 2mm shims under wher the camberlinks is on the shock tower in the rear to give it a more plantet feeling is it that u mean??
#9530
on the front where the steering linkage connects to the steering knuckle arm
#9533
ChrisJ - are you guys going to post Dirtinator's setup for his Pro4 win this past weekend at the Southwest Indoor Grand Prix?
http://www.teamassociated.com/news/r...r_Grand_Prix__
#9534
2mm shims or do i have to buy them from my LHS
#9536
i was not at the showdown , i was at the Indy-rc event
I just want to say that "pulling a wheelie" with the stock pads doesnt really mean that they work, the stock and HD pads are both hit or miss and not consistent and its simply because of the material. The garodisc are more consistent and provide more grip when needed. anyone that owns them will tell you that if you make the stock pads slip anywhere past 3' feet they will not make the end of a qualifier. the garodisc can slip 5' and still provide more grip while they are slipping than the HD pads. we all know you can tighten the stock pads down enough to work but having smooth power delivery is the key. 2 discs are 17.00 and will never wear out, Sym has had the same set on his truck for 2 months now with no maintence or re adjusting, i havent touched mine in weeks. with the pin mod on anything except high bite clay you only need two.
#9537
http://www3.towerhobbies.com/cgi-bin...&I=LXEAE0&P=FR
Terry
#9540
No, you have to buy them. I bought 2 packs of the ball stud washers. Part #9630
Terry
Terry
5Likes
