Like Tree5Likes
SC10 4x4 Thread
Old 10-26-2011 | 12:39 PM
  #9556
Wild Cherry's Avatar
Tech Legend
been hearing Ae is even recommending
getting one of those basket things .....
Wild Cherry is offline
Old 10-26-2011 | 12:55 PM
  #9557
JS's Avatar
JS
Originally Posted by Chris Jarosz
I'm sure it will be posted. I will go check when.
Very Cool - Thanks Chris
I see a winning streak forming here with the SC10 4x4
JS is offline
Old 10-26-2011 | 02:20 PM
  #9558
CraigMBA's Avatar
Originally Posted by CoyoteSlash
IE: A/E guys. The Ryan's were not pinned.
I don't believe in the accuracy of that setup sheet, but even if they weren't, they used a multi-disc slipper. Also, the setup sheet was far from complete. A close look at the pictures shows one huge thing that isn't listed on the sheet....
CraigMBA is offline
Old 10-26-2011 | 02:44 PM
  #9559
JayL's Avatar
R/C Tech Elite Member
I can't speak on everyone's behalf, but alot of guys I have seen are running the Fast Lap Products clutch basket. I haven't seen/heard of any team guys pinning the top shaft.
hmmm, guess I won't either
JayL is offline
Old 10-26-2011 | 03:12 PM
  #9560
symmetricon's Avatar
Chris J,
Is there a reason for not using steel inserts where the outdrive go out of the diffs? My only gripe with the truck is that the copper wears quicker than I like, which causes leaking and wobbly outdrives. At least the diff cups are fairily cheap to buy.
symmetricon is offline
Old 10-26-2011 | 03:16 PM
  #9561
kghills's Avatar
Originally Posted by symmetricon
Chris J,
I find if you double shim under the cross pin the outdrive wobbles less and seems to not wear the case as quickly.
Keith.
kghills is offline
Old 10-26-2011 | 03:26 PM
  #9562
Keith.
I have done this, and it does help. But I would think that steel whould be much more durable, especially in a high wear area.
For instance, and I just checked with my calipers, the outside of the copper insert one one of my diffs is 5.4mm, while the inside is 5.06mm. Because the outside is worn, the grease does not stay in, then the diff leaks. Then the wobble in the diff causes the pin to press and deform the shim underneath the sungear causing even worse leaking.
Old 10-26-2011 | 03:41 PM
  #9563
kghills's Avatar
I have had this happen with a single shim. Case would have about .010" wear but the shaft was fine. With the double shim and new cases I am not seeing the wear.....yet. Can't help but wonder if the case used a steel insert and a single shim if it would not then destroy the case and outdrive shaft.
Keith.
kghills is offline
Old 10-26-2011 | 03:45 PM
  #9564
Keith.
Good question, except in my rc8, the diffs last forever. They have a single shim and have steel where the outdrive go into the diffs. I have had the same diff internals for 2yrs in my rc8e. Now the case itself wears out where the screws tighten down the two pieces, but the steel insert, and the outdrives do not wear.
Old 10-26-2011 | 04:15 PM
  #9565
Thumbs up Fast Lap Products Parts
Chris,
Have you checked out Fastlapproducts.net lately? They have added new products. Everything looks pretty cool. I'll have to place an order.
ofrdracer is offline
Old 10-26-2011 | 04:17 PM
  #9566
Divey's Avatar
RC8/RC8T diffs are the reason I love AE brand. I have never stripped nor wear out any diffs in my 3 truggies and 1 buggy ever. From bashing to racing to landing full throttle on 6 cell. There diffs are high qaulity for sure.
Divey is offline
Old 10-26-2011 | 05:04 PM
  #9567
tony montana's Avatar
what diff oils should I run if I dont have the pin mod or clutch basket. I dont have 30,000. The thickest I have is 10,000. Was thinking of trying 10,000 front and 5,000 rear
tony montana is offline
  #9568
Thumbs up Clutch Basket
I just talked to Billy at fastlapproducts.net . He says he is now including a modified clutch cover with his basket kit for the same price. Pretty good deal.
Old 10-26-2011 | 05:05 PM
  #9569
1Fastpede's Avatar
Regardless of where a spacer is it all comes down to clamping force of the spring x friction surface. you can put 4mm of spacer it doesn't matter its simple mechanics. Maybe you lucked out and got a good spring that all of the kits should have had. I've spent plenty of time on the phone with AE been through 5 different local trucks 10 different new springs/ thrust spacer packages and non of them worked. by using a spacer all your doing is moving the components on the shaft outwards. your not increasing clamping load. The basket doesn't even increase clamping load that is all done by the spring. the basket just adds another friction surface.
In a perfect world you would want a super stiff spring but that would require a much larger dia. shaft. to hold the torque.
You should send your truck to AE because they seem to have to use a basket as well and your truck would be perfect specimen. I'm serious.
1Fastpede is offline
Old 10-26-2011 | 05:14 PM
  #9570
CraigMBA's Avatar
30 or 60 in the front, 5 or 7 in the rear. I'm serious.
CraigMBA is offline
