SC10 4x4 Thread
#2056
#2058
Seriously, the only thing you are doing is complaining and making ridiculous comments on this thread so how about you enjoy your day off and go chill out instead of waisting forum space........
TBJ, how have the temps been on your motor/esc? I'm going to try the 2400kv castle motor just to see how it performs against my 3800kv motor.......
#2060
#2061
Not sure on links to build your own, but there have been several users on here that have, hopefully that can provide you that info.
#2062
#2063
i wouldnt waste your time on it like i already did
like i said before the motor needs more cowbell
#2064
The 2400 motor IMO is more of a bashing motor not racing they are made more towards the 3s batts instead of 2s, there are better motors to use that are cheaper too and able to get more speed, like the 1410 or 1406 and stay cool, ive been running a 3800 and my esc fan never turns on in my rx8. the motor gets alittle hot but works great.
#2065
I think I had this problem, and it was because the shaft that goes through everything wasn't lined up properly (the hex on the shaft wasn't inside the hex on the bottom half of the saver.)
Pre-compress the spring, make sure that you line up the shaft properly, and it should go on, but it will take a little bit of effort.
#2066
The 3800 has better speed/longer run times/and never gets hot if geared correctly, that good enough? Again, I've used them both and would take the 3800 over the 2400 every day of the week.
#2067
From: Norwood, OH...and CCRCR and The OhioRCFactory
ThunderbirdJunkie believes gearing up may help keep the speedo cooler, but mind you this was only one run, and the belt may be a bit tight. The speedo gets warm quick, FWIW.
#2068
#2069
MM seems to be getting a little hot, motor is in the 130s? Running a 15t Robinson pinion with the kit 32p spur (62 or 63? whatever it is). Mind you that's after a whole pack, and after about 12 or 15 minutes the battery only took 3300mah.
#2070
But ya know what they say, loose is fast
5Likes
