SC10 4x4 Thread
http://www.hobbyking.com/hobbyking/s...ddle_Pack.html Go for the UPS 3 day shipping you will get them much quicker.
Under "User CP", under "Settings and Options", it's titled "Edit Ignore List". You start typing in the name of the user you are trying to ignore and it will self generate a list.
It works awesome if users who post repetitive stuff annoy you, or for getting rid of trolls, or the insane, or whatever.
Thanks, that'll improve the experience here alot.
Was just thinking up a hypothetical reason for those having an issue in that race clearing the monstrous high speed triple, and those that have flight pitch control issues. Is it plausable to consider that the chassis brace or even exotek chassis may stiffen up the chassis to the point of contributing to the bad flight charachteristics compared to other vehicles?I held the vehicle and accelerated with the brace on and stabbed the throttle, than did the same without brace. It seems that the downforce and torsional pull is stronger without the brace?Just something to think of..
What's your diff fluids? The easiest way to calm down steering is to throw a negative curve in your radio on the steering. I think I'm at -20% on my KO, but I'm also running a stupid fast servo.
Going really heavy up front (like 30k) will help a lot.
I'm going to a race next weekend that usually has a few good sized jumps, we'll see how it goes. I'll be going with a new body that I'm going to vent really aggressively. More so than any of the bodies I had on my Losi previously.
I also have the Exotek now and am going to add even more weight (probably about 4-6oz) and corner balance the truck.
I'll report back, but it's a bit away.
Oh so you want less steering.
It's easy to mess with while you are on the stand. Make changes in -5% increments then drive a bit, change it again, drive a bit, etc.
That's what I do, depending on the track I may run more or less curve.
I'm not familiar with the Airtronics but I think it's expo on those radios. Try like -15 or -20%.
I don't think it's that. I think it's a weight/inertia thing. The truck is lighter, a lot lighter, so is more susceptible to the parachuting effect. A lot more so than with the Losi.
Sounds good heavyD!!
Yes, and the truck feels so different. Almost like a 1/10 4wd buggy.
5Likes
