SC10 4x4 Thread
#1877
#1880
#1883
From: Norwood, OH...and CCRCR and The OhioRCFactory
Dude, honestly, did you pay somebody else to build the truck for you? It's a 6mm axle. Says so right in the instructions when you're assembling the CVAs and putting bearings in the carriers.
#1884
Having an issue with off power steering. I think a sway bar might help, but i'm just not getting enough. I am now using the clicker, but it still isn't great.
What have you found that works?
Stock springs, 35 front 30 back shocks on inner on top and outer bottom. Long camber links front and back
#1885
The front and rear body mount brackets (manual pages 14 &15) are the exact same width and location as as the mounts for 2wd and 4x4 Slash which is fantastic since many of us have bodies already drilled for Slash we would like to run on the SC10 4x4 too. Thanks AE! However, the posts themselves have an odd 1/2 inch 'cobra head' offset, which pushes the Slash body either a half inch too far forward or rearward depending on which direction you install the offset. Straight posts would be perfect and all your old Slash bodies will drop right on without having to drill any new holes. I sure would like to slap whoever spoiled perfection by making the silly offset posts, lol. Does anyone know of any straight square body posts from another vehicle that would slip into the square hole of these body mount brackets?
#1887
Oh ya, i payed someone to build my truck
. Because i totally check what the size of the axle is when i put my truck together... Honestly who looks at the specs of the axles when putting a truck together that you have been waiting forever for? I no i didnt, i was looking at the instructions to get it built and finished to have some fun with it.
#1888
#1889
. Because i totally check what the size of the axle is when i put my truck together... Honestly who looks at the specs of the axles when putting a truck together that you have been waiting forever for? I no i didnt, i was looking at the instructions to get it built and finished to have some fun with it.Your inability (or lack of desire) to help yourself is slightly unnerving.
5Likes
is stipping hexes like other people at the track
