Like Tree5Likes
SC10 4x4 Thread
Old 06-19-2011 | 12:16 AM
  #3376
OSherman's Avatar
Thumbs up Tekno RC Hex hubs
Yup.. i bought a set tonight and mounted them up.. nice fit on the axles, no bind with included shims.
OSherman is offline
Old 06-19-2011 | 01:26 AM
  #3377
w00kie's Avatar
anyone had a problem with the belt coming off the front pulley under a short drive, With some hard breaking and turning.
once i set my tensioners (front and rear) to max tension, it seems to have stopped the problem. Although im unsure if it is too tight.
if i take the motor off the pinion, it rolls nice and smooth for a few feet after a short push.
the truck runs nice now, although it doesn't seem too tight, i just think that with the tensioners set to full tension, it seems wrong to have this.
also i run a tenshock 5200kv 4 pole motor with a sc8 speedy from hobbywing.
thanks guys.
w00kie is offline
Old 06-19-2011 | 01:45 AM
  #3378
SaladFork's Avatar
thanks guys.
Never have slipped a belt but did have a clicker melt.
I have the Tenshock 5200 but have yet to run it, how are your temps?
SaladFork is offline
Old 06-19-2011 | 02:33 AM
  #3379
murky123's Avatar
Originally Posted by JEFFs SC10
Since there's no cogging with the 4 pole CC motor
no cogging with the sensorless 1410
sure there is cogging. try driving very slowly from a stop, and you will see that this motor does cog a bit..
murky123 is offline
Old 06-19-2011 | 04:55 AM
  #3380
w00kie's Avatar
temps are great. running a 11t pinion with the stock spur, 32 pitch, getting roughly 60 degrees celcius. with a 13 roughly 90 degrees celcius.
ill let you do the math.
w00kie is offline
Old 06-19-2011 | 05:30 AM
  #3381
ffpm46's Avatar
What 540 motors have people been using with success?
Thinking about trying the saddle configuration.
ffpm46 is offline
Old 06-19-2011 | 05:34 AM
  #3382
ffpm46's Avatar
Anyone using these?
Tekno RC 12mm Aluminum M6 Driveshaft Hex Adapter Set (4)
[TKR1654X]
http://www.amainhobbies.com/product_...-Adapter-Set-4
ffpm46 is offline
Old 06-19-2011 | 06:39 AM
  #3383
JEFFs SC10's Avatar
I must have a special motor I have hardly any cogging at all. No hesitation what so ever.
JEFFs SC10 is offline
Old 06-19-2011 | 06:52 AM
  #3384
ilanstylz's Avatar
I have that same special motor, whenever I do my first practice runs on the track I always start out real slow, and I've never had a cogging issue at all with the 1410 motor.........
ilanstylz is offline
Old 06-19-2011 | 06:57 AM
  #3385
rcpilotjr's Avatar
I ran a velineon in my ofna before I sold it. now waiting for my AE 4x4 backorder to get to my LHS (hint hint AE rep, Back in stock this coming week?). FD ratio was 13.65 and it had NO problem pushing that truck around. I was runnin the same times as people with Novak Ballistic 550s...
rcpilotjr is offline
Old 06-19-2011 | 07:00 AM
  #3386
JEFFs SC10's Avatar
hmmm maybe the same special China man built out motors.
Old 06-19-2011 | 07:14 AM
  #3387
ilanstylz's Avatar
If you ever find out who the man is lemme know so I can thank him, my 1410 motor is performing just as great as my 5.5 sc4x motor ;-)
Old 06-19-2011 | 08:39 AM
  #3388
Matt Howard's Avatar
Amainhobbies has the lightweight front and rear topshafts in stock, just ordered one of each, along with the Tekno clamping hubs.
Matt Howard is offline
Old 06-19-2011 | 08:45 AM
  #3389
ilanstylz's Avatar
Not sure if this was already asked/answered, but will these fit with no issues or modifications:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBAHG&P=7
Old 06-19-2011 | 08:48 AM
  #3390
No, those are for the 2wd SC10.
