Like Tree5Likes
SC10 4x4 Thread
Old 10-23-2011 | 10:46 PM
  #9346
CraigMBA's Avatar
Originally Posted by CoyoteSlash
I tore up another Idler gear today, and replaced it on the bench in 20minutes. My slipper is 1mm from flush, with stock pads and I stripped it. Which worries me. But I have 4 more. For 5 hours of fun. It was worth a fix.
At this point I think I'd try changing the trans case.
CraigMBA is offline
Old 10-23-2011 | 10:54 PM
  #9347
CoyoteSlash's Avatar
The wobbly Diff issue? or something else with the case aside from the diff? Just curious. Thanks for the suggestion.
CoyoteSlash is offline
Old 10-23-2011 | 10:59 PM
  #9348
CraigMBA's Avatar
I'm thinking it's something misaligned.
CraigMBA is offline
Old 10-23-2011 | 11:03 PM
  #9349
It's worth a shot. But I have to say that the idler's blowing up are clean strips with whole teeth broken off into the Top Shaft. I'm not really sure it's an alignment thing from that evidence. But I will try anything. Thank you much.
Old 10-24-2011 | 04:33 AM
  #9350
Wonder if that lcg chassis would help belt drive stay straight or would u still need that rod brace
rickybobbyxxx is offline
Old 10-24-2011 | 04:39 AM
  #9351
fastrc64's Avatar
Originally Posted by Farmer_John
Non basket garodisc users, what are you using as a starting point for slipper tension? 3.5mm as stock, or something tighter/looser?
I searched back to the introduction of the product and my eyes are getting too heavy to continue going through posts.
the best way to find the sweet spot for the slipper is too start loose and give it some gas. if that is loose adjust and try till your truck slips for about two feet . then do a lap and the result should be as you come out of a corner the truck should sound very smooth and quite but have a sort of whistle sound
fastrc64 is offline
Old 10-24-2011 | 04:50 AM
  #9352
fastrc64's Avatar
Default left and right balance
I literally just took a hammer and pounded the Futaba Servo Horn on it.
I'm an idiot Genius.
one way to fix the problem is to set ur truck up with a lot of steering and then use only about 60% on the duel rate and you'll be just fine (make sure you have ur left and right adjusted correct that is a major factor in any setup)
fastrc64 is offline
Old 10-24-2011 | 06:16 AM
  #9353
1fastslash's Avatar
Default GARO DISCS KICK BUTT !!!! THANKS MARCUS
Got my GARO DISCS and I love them !!!! they work great the slipper finally works like it should . I just kept cranking the nut down until I liked the way it performed .It slips for a foot or so on carpet but it hooks up too its hard to explain other than just saying it WORKS!!! I can pull the front wheels coming out of a corner which I have never been able to do its like a whole new truck . Until i hit a tree root and tore up the front suspension . Thats another story though .. lol
1fastslash is offline
Old 10-24-2011 | 07:22 AM
  #9354
SourDieselX's Avatar
On the topic of Gen Ace batteries, I picked up two last week, when I got them, one of them was totally dead, my wouldn't even register it, also didn't have a single volt in it. The other gen ace lipo worked great, no problems at all, I used it about 3-4 times on Saturday and it ran great. My main lipo is a team orion 6500mah 90c and that thing is a beast and I love it. Thinking that might be where I need to be at. Still waiting to see if Hobbypartz will replace that dead lipo for me.
SourDieselX is offline
Old 10-24-2011 | 08:30 AM
  #9355
Originally Posted by symmetricon
Symmetricon thinks that SourDieselX is right. Symetricon is free this friday and saturday.
Cjtamu says y'all suck LOL. It is Mrs. Cjtamu's bday Saturday and he will definitely NOT be going to the track with y'all. Itching to drive this thing again too, making a few setup changes after running a pack this weekend. Sym, my clicker was actually in the "on" (2mm) or whatever you want to call it position Saturday. I think locking it down and running a little less dampening is going to put the truck close, even before doing the pin mod.
cjtamu is offline
Old 10-24-2011 | 09:31 AM
  #9356
Mizchief's Avatar
Okay. I feel really dumb asking this.
My Spektrum 6030 JR spline Servo:
It 'will not' align. I am using the transmitter to send the server 20/25 points either direction to get the spline to line up for a vertical mount with the servo horn.
Setting the Transmitter at zero and trying to align the servo to a vertical servo horn is impossible. I have to send the servo so far one direction that it actually loses 'alot' of steering in whatever direction I compensated with. It's seriously sitting at Zero, and exactly 20 points either direction (on transmitter) will make it line up.
I've done hundreds of servo alignments. This servo is pissing. me. off.
anyone have a 6030? Till now i've just pretended I didn't have this problem. Now that my truck is drivable. I'm getting back into this.
Oh. Interesting. I saw the 99.99$ ones a while ago. 45C I think. hmmm. Thanks.
I had the same horn alignment issue with the SAV-SC-1256TG. I just used about 30 clicks of sub trim to square it all up prior to mounting to the body (god help you if you need to get to the servo after finishing the build)
I didn't have a problem with max throw as for that servo I had to dial the endpoints down to 80% to prevent binding when steering reached the max throw.
Something else to look at, on mine the horn would get caught on the servo housing as well, but wan't an issue once the rack was connected as it didn't allow for that much throw anyway.
Mizchief is offline
Old 10-24-2011 | 09:36 AM
  #9357
SourDieselX says there is always another day, you'll just be one day behind in tuning then we will be, haha. I'm going to start the tear down of it today, going to change the diff fluid to about 5k, maybe swap from 22.5w to 25w in the suspension, few more little tweaks, Jason was able to help with a issue that I was having at the track which was causing me to slide out every time I let off the throttle hence all my spin outs on the end of the straight. This truck has so many tweaks but it's fun learning them and working on them. Just need to keep practicing and improving my driving and all should be good!
Old 10-24-2011 | 09:44 AM
  #9358
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Now ThunderbirdJunkie feels like an idiot.
He used a 6040 and knew of the similarities between the Spektrum and Savox servos...
Since he used a Futaba arm on his Savox 1258, he figured it'd be a Futaba arm on the Spektrum servo too.
Always wondered why it was so tight on there
T-BirdJunkie is offline
Old 10-24-2011 | 10:57 AM
  #9359
Divey's Avatar
Anyone cutting any holes in the stock body. I am thinking of getting the Proline or Jconcepts body but I would rather use this one up first.
Divey is offline
Old 10-24-2011 | 11:30 AM
  #9360
symmetricon's Avatar
Son of a gun, it happens to be Symmetricons birthday on saturday as well, which happens to be a great excuse to get out to the track Symmetricon thinks your truck felt darn good with all things considered, and it should feel better once the clicker is locked down, and with lighter shock oils. It is crazy how drasticly different this truck can feel depending on the tuning.
I had to +30 on the subtrim on my servo once it was assembled. I checked and rechecked, with the servo alignment tool. My endpoints are around 80L 80R, and my D/R is around 80 also. No harm no problem.
symmetricon is offline
