SC10 4x4 Thread
So in this case, its something worth trying. I had hoped to hear WC try it out but from what I understood the issue was that no one had it around him. As there appears to be people who have it around him, I was curious to get his honest opinion on the device from personal usage or at least driving someones vehicle.
DRY
- Low traction to slick
- semi hard packed with dust to loam off of the line
- bumpy
- big air 1/8 jumps
WET
- Sticky when reasonably watered to greasy when soaked
- Medium to high traction
- bumpy
- Big air jumps
usually, get more of the dry condition as the watering is done for the 2wds first, the 4wd SCTs run a lot later in the series of heats so by the time they go, its usually not wet at all.
Marcus' RC Shox starting setup did have A LOT of steering, very aggressive as you described. with a bumpy surface, I needed to go to a softer spring in the rear, whites felt good. Also went down on rear oil with his pistons.
His Center diff in these conditions though was money. Maybe it has something to do with it performing better in low traction conditions (even with the pins) than the VTS style setups?
When I ran my vehicle on similar conditions with my clutch basket, in comparison to the Center Diff the center diff would allow (at least, this is how I saw it) the front end to pull me through trouble spots were the clutch basket style setup would wash out in the rear.
funny, that is the reason I went away from any clutch basket / VTS and tried the center diff and won't go back to a VTS style setup, lack of performance in comparison.
but to each his own.
I figured that as a racer you would have at least tried it, even if it meant wheeling someone else's vehicle to see if there was a benefit. At least, that is what I would have done as I want that advantage if there is one, and it makes easier to comment on something by actually trying it versus speculation.
When I see a good driver with that part have nothing but slow laps & failure to clear even simple jumps ?
Then see his times improve and make the jumps easy with VTS ?
I have to steer everyone towards the VTS ,Ok ?
Thanks, my conditions (bear with me, my track description skills are not the best) would be:
DRY
- bumpy
- big air 1/8 jumps
WET
- bumpy
- Big air jumps
DRY
- bumpy
- big air 1/8 jumps
WET
- bumpy
- Big air jumps
Try Kody's setup with the C-diff and adjust diff fluids for it.
Good drivers like twitch and quick response cars. This mortal like slower response and more forgiving. And I have heard no one say the V2 C diff messes up jumping. You have to use the right amount of pins. Well that is my understanding.
i just did the brain kinwald set up.. made the truck very predictable and more consistent.. the rear end was not as loose as normal.. maybe this is the ticket for high bite indoor tracks.. but i cant say it will work for outdoor..
Personally if it was me, I would have directed him to speak with RC Shox to see about helping him out. Like I would have done if he was having issues with his VTS.
+1, that is what I am wondering if something wasn't done right, or if help is needed to contact RC Shox. Very helpful.
I was trying my truck at the track and hating it. and the fast guy drove my truck and said it was fine. So i guess he likes it all loose, but his driving style is like 3/4-full throttle everywhere. He just powers through the corners, I cant drive like that.
Is it the same to remove the blue coloring off of the titanium turnbuckles from the FT truck as it would be to remove the blue off of aluminum FT pieces? I was planning on using lye to remove it but want to make sure it would be okay on the turnbuckles
Stick pack is cool if you can get the right weight on both sides. I personally like saddle packs for my sc10 and shorty packs for my b4...........................
5Likes
