Like Tree5Likes
SC10 4x4 Thread
Old 07-18-2012 | 06:15 PM
  #26776
JEFFs SC10's Avatar
Originally Posted by Wildcat1971
@snafu, I after i replaced my rear diff shims and diff oil, I reassembled my car and left the rear belt off, it spun the same if I put the slipper on or not, so I dunno what is binding on yours.
I beat my record, only 1 hour this time to reshim and change diff fluid........ lol. I will give the truck this, it really handles was on black top....... lol. I put the exotek front locker in. The only difference I could tell in the street is that the front tire peeled out and the rear slipped. I could actually see the front pull the rear around. Hopefully this helps me on the track. This is the last mod/upgrade.part i plan on buying. Really hope the truck is drivable now. does not have to win every race, just drive in a straight line.
on a side note. who here believes in radio lag? Because I think I might be getting some radio lag. Please dont ask me which radio i have and suggest I get a spektrum like 90% of the people out there, lol. Just asking if you believe and radio lag and what it feels like to you.
get a Airtronics and call it a day. Just my opinion.
JEFFs SC10 is offline
Old 07-18-2012 | 06:17 PM
  #26777
fq06's Avatar
he told you not to do that
(100% agree with you on the airtronics though)
fq06 is offline
Old 07-18-2012 | 06:20 PM
  #26778
JEFFs SC10's Avatar
heheh
Old 07-18-2012 | 06:22 PM
  #26779
Wildcat1971's Avatar
lol, darn you, I said dont suggest a new radio, lol. I ask what it feels like to you. Mine feel like turbo lag. I rip the trigger and it paused then goes like a bat out of hell, lol. Would a low C rating cause the same issue? My pack is room temp. no heat.
Wildcat1971 is offline
Old 07-18-2012 | 06:23 PM
  #26780
I had an airtrinocs m8 and sold it for a 2.4 ghz radio. I wont say which one, because every issue i have will be blamed on my radio lol. I will come here and be like, my truck is pushing and people will say its your radio..... lol
I really liked my M8, but I think i was glitching, and wanted to go 2.4 ghz after some guys were teasing me about my "sword" lol.
Old 07-18-2012 | 06:26 PM
  #26781
JEFFs SC10's Avatar
no that's kind of weird. Is there a setting to adjust?
I would call their tech line.
Otherwise sell/junk that radio and get the Airtronics!
Old 07-18-2012 | 06:30 PM
  #26782
well, I changed motors, and the esc and it still exists. The drive line is free. Its not binding. But when you trying to come out of a corner and it pauses, so i give it a little more gas and boom, I get it all at once start bouncing off pipes. It is kinda hard to drive to tell you the truth. I am use DR on the radio. my dr is at 50%, would that do it? I thought DR was steering only.
Old 07-18-2012 | 06:31 PM
  #26783
Jake S's Avatar
a friends spektrum dx3s did the same thing only way to get it any better was to lower the neutral range on the esc, and then turn the throttle trim so the wheels would just move while at neutral then back the throttle trim off 2-3 clicks.
im curious if it has something to do with the internal spring on the throttle.
add: also maybe the minimum drive is set high on your speed control.
Jake S is offline
Old 07-18-2012 | 06:38 PM
  #26784
I used the same radio with my b4 and dont notice the issue. But i dont use DR on my b4. So it could be a faulty receiver I guess. I will check the neutral on the esc. I can narrow that. But it also does it from 1/4 throttle to full throttle. If i coast at 1/4 throttle then punch it, it will pause then explode with power. Does not do this on the bench with wheels off the ground....... Thats why I asked about C rating.
Old 07-18-2012 | 06:40 PM
  #26785
also, I dont use expo, I like my throttle and steering linear. I only set center, end points and DR for my truck to calm the steering.
Old 07-18-2012 | 06:42 PM
  #26786
fq06's Avatar
what's your expo at?
Try zero and see if that fixes your issue and then add expo to your liking. You really shouldn't be over 20% max though. Especially if you have a curve built into your esc on top of expo... oh man.
Edit: DR is travel adjustment... steering only. No effect on expo. But expo is steering and throttle.
fq06 is offline
Old 07-18-2012 | 06:55 PM
  #26787
fq06's Avatar
Spectrum
fq06 is offline
Old 07-18-2012 | 07:16 PM
  #26788
I dont have expo set. its linear. I put DR back to 100% to see if it chaged, it did not affect the throttle, but ........ the truck was impossible to drive at 100%. I will stay between 50-60% DR.
Old 07-18-2012 | 07:18 PM
  #26789
Spectrum
lol, not a spectrum.
Old 07-18-2012 | 07:21 PM
  #26790
Well, I will probably try to swap my receiver next. I ran on the street for 5 mins. Came of at 115 motor temp. 115 esc temp, 95 battery and 100 on the esc wires. The chassis was 96 deg is anyone cares, lol. Its hot here in AZ. Chassis was hotter than the battery, lol.
